GC/Koni Yellow adapter?
I've got a couple of questions about the Ground Control and Koni yellow setup on my GSR.
- A buddy of mine is selling me his ground controls but i think he's running neuspeed shocks. Do i need a special adapter or sleeve to use the koni yellows? If so, is there a way to buy just the sleeve?
Thanks guys
Thanks guys
Re: GC/Koni Yellow adapter? (gsrghost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrghost »</TD></TR><TR><TD CLASS="quote">ground control sells a different sleeve for yellows.</TD></TR></TABLE>
yah.. but i herd the neuspeed one was the same - i just wanted to make sure
Re: GC/Koni Yellow adapter? (VtecAdvantage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecAdvantage »</TD></TR><TR><TD CLASS="quote">I've got a couple of questions about the Ground Control and Koni yellow setup on my GSR.
Thanks guys</TD></TR></TABLE>
why not just look at the gc sleeve and see? if it has the indent on the bottm of the sleeve like the konis do then it should fit.
Re: GC/Koni Yellow adapter? (civicdxtyper)
There should be a black adapter in the sleeve to fit on Koni yellow shocks. GC might sell them separately, call them and ask
Re: GC/Koni Yellow adapter? (ingrate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ingrate »</TD></TR><TR><TD CLASS="quote">There should be a black adapter in the sleeve to fit on Koni yellow shocks. GC might sell them separately, call them and ask</TD></TR></TABLE>
Yah, i've been looking but haven't found any. I wasn't sure who deals with GC, im pretty sure its Eibach right?
thanks
thanks
I believe the adapter for konis is different than all the other shocks. I think it's a little ring that fits inside the sleeve to make it sit on the koni perch. You can buy it directly from ground control, just give them a call and they'll help you out.
Are these Neuspeed Koni shocks your friend is using? If so then they should fit your Konis.
My GC's for my Konis did not have any adapters, the ID of the sleeve matched the shock exactly and it had a machined lip to sit on the shock's spring perch snap ring.
Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Are these Neuspeed Koni shocks your friend is using? If so then they should fit your Konis.
Exactly. If the GC's are Koni specific, they will just rest on the snap ring of the Konis without any sort of adapter. If they are not Koni specific, they will need the adapter.
The Neuspeed SP3's are Koni Yellows with more snap ring perches. If he was using them without any adapter, you won't need an adapter when going to straight Koni's.
importdude2000
Suspension & Brakes
06-17-2007 07:28 AM
