b18 or b16?
Old Aug 8, 2006 | 01:31 PM
bboysake's Avatar
Default b18 or b16?
Hey I'm not sure if there is a post for this already but for an Ls motor would you rather have a Gsr head or a b16 head? Which is better?
Old Aug 8, 2006 | 01:37 PM
Lan's Avatar
Lan
Default Re: b18 or b16? (bboysake)
gsr>more compression
b16>flows better
Old Aug 8, 2006 | 01:39 PM
bboysake's Avatar
Default Re: b18 or b16? (Lan)
So you're saying b16 is better? Well I still want low compression but I heard gsr head is better? I'm so confused on them! I'm leaning toward b16 tho...Unless someone can convince me to go b18???
Old Aug 8, 2006 | 01:41 PM
Lan's Avatar
Lan
Turbo or N/A?
Old Aug 8, 2006 | 01:53 PM
bboysake's Avatar
Turbo
Old Aug 8, 2006 | 02:00 PM
Lan's Avatar
Lan
B16
Old Aug 8, 2006 | 02:24 PM
95 integra's Avatar
gsr
Lan's Avatar
Lan
Default Re: b18 or b16? (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">gsr </TD></TR></TABLE>
With GSR cams
Old Aug 8, 2006 | 02:56 PM
bboysake's Avatar
ok got it! haha
Old Aug 8, 2006 | 03:20 PM
phateless's Avatar
so that means gsr head would be better for n/a? if you're planning to go ls/vtec and then just leave the damned thing alone...
Old Aug 8, 2006 | 03:21 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: (bboysake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboysake &raquo;</TD></TR><TR><TD CLASS="quote">Hey I'm not sure if there is a post for this already but for an Ls motor would you rather have a Gsr head or a b16 head? Which is better?</TD></TR></TABLE>
GSR head with a 00spec CTR/ITR intake cam
Old Aug 8, 2006 | 06:51 PM
enil01's Avatar
Default Re: (JDM turbo DC)
b16 with a thinhead gasket. Best of both sort of...
Old Aug 9, 2006 | 08:07 AM
bboysake's Avatar
Default Re: (phateless)
Well I forgot to mention I am Ls-Turbo...
Old Aug 9, 2006 | 08:31 AM
rkrone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC &raquo;</TD></TR><TR><TD CLASS="quote">GSR head with a 00spec CTR/ITR intake cam</TD></TR></TABLE>
Old Aug 9, 2006 | 09:31 AM
HONDA RR's Avatar
Gsr head will give you a better compression it also depends for what application. If your going turbo your better of with a b16 head.
Old Aug 9, 2006 | 09:36 AM
JDMxDB8's Avatar
GSR w/ low compression pistons
Old Aug 9, 2006 | 10:10 AM
phateless's Avatar
so right off the bat, the gsr head will give you more power?
Old Aug 9, 2006 | 10:38 AM
dohcMONSTER's Avatar
good lord there is a lot of misinformation here
A GSR head flows more midrange, has a smaller combustion chamber, and will raise your compression.
A b16 head flows better up top, has a larger combustion chamber and will lower your compression.
the biggest factor though for you between these heads will be what cams your running, if its streetable and the lift on the cams. A very high lift cam with a p72 head will actually flow the same or better than a pr3 head, but if you use a more mild cam set-up then the pr3 head will flow better than the P72 up top.
My advice would be whatever head you go with, get it ported to reduce spool time and increase efficiency
Old Aug 9, 2006 | 11:20 AM
phateless's Avatar
there's gotta be a thread somewhere with dyno graphs of completely straight LS/VTEC builds, comparing the pr3 and p72 heads. i've been thinking of slapping a vtec head on my ls motor, but i'm not going to build it up or turbo it, or anything of the sort, i'm just gonna leave it stock. you're saying they'll give similar power, just a different power curve? and the p72 will give you more top-end but the pr3 will give you more midrange...?
Old Aug 9, 2006 | 11:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phateless &raquo;</TD></TR><TR><TD CLASS="quote"> and the p72 will give you more top-end but the pr3 will give you more midrange...?</TD></TR></TABLE>
other way around, read my post above
Old Aug 9, 2006 | 11:33 AM
phateless's Avatar
right, sorry.
ran a search for "lsvtec" and this thread was the very first one that came up
https://honda-tech.com/zerothread?id=1676914
Old Aug 9, 2006 | 01:17 PM
bboysake's Avatar
Default Re: (dohcMONSTER)
I plan on running a stock gsr head...maybe building it some...but I should get new pistons and rods on a turbo ls? What's my best bet here for building ls-vt? Just parts wise...
Old Aug 9, 2006 | 01:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboysake &raquo;</TD></TR><TR><TD CLASS="quote">I plan on running a stock gsr head...maybe building it some...but I should get new pistons and rods on a turbo ls? What's my best bet here for building ls-vt? Just parts wise...</TD></TR></TABLE>
search
Old Aug 9, 2006 | 01:27 PM
search
» Search Results
Your search for lsvtec returned 953 results.
SwappedTURBOegg
93
Oct 30, 2009 12:00 AM
88 EF Hatch
Nov 27, 2008 06:45 PM
teefunk01
Oct 9, 2005 07:30 AM
90teg
Jul 2, 2005 11:22 PM
LBR92DA-T
Dec 11, 2003 02:16 PM
