starting problem
Old Aug 6, 2006 | 03:58 PM
Wmartir123's Avatar
Default starting problem
i have a 96 integra and its been starting up fine every day until today
i came home from work and start it and it wont start battery is fine, all i hear is the click from the main relay thats it what to do ?
Old Aug 6, 2006 | 08:14 PM
jared99's Avatar
Default Re: starting problem (Wmartir123)
Do you not hear the starter turning over? I might start with that if you don't hear the starter motor doing anything.
Old Aug 6, 2006 | 11:43 PM
dmacaalay's Avatar
as stated in HAN.. check your battery terminals.. if they have a bad connection, it could be the problem.. if its clean, try jumping the battery.. if its not turning over at all, bad starter.. tapping it could be a temp. fix, but might as well get a new one..
Old Aug 7, 2006 | 06:09 AM
Duane_in_Japan's Avatar
Default Re: starting problem (dmacaalay)
Your battery may run the lights and the radio but it needs tons of power to crank the starter, put a volt meter on it and turn the key, let us know what it shows, 12 volts or drops down to 5 or something. Ignition switches do go bad, is it in park, like mentioned, get it jumped and clean cables and terminals.
inaety
Jun 24, 2011 12:57 AM
xander1100
Oct 18, 2009 07:56 PM
EF 1990
Feb 18, 2009 10:23 AM
whatcivic
Dec 6, 2005 05:20 PM
Vinny Chase
Jun 23, 2003 02:56 PM
