starter question
Old Sep 9, 2006 | 12:16 AM
sle.simon's Avatar
Default starter question
does it matter what kinda of starter i buy? if so what would be a good starter for cheap for my 94 teg LS it's stock and i dont plan on doing any thing more then IHE help! i'm a noob when it comes to these things.
Old Sep 9, 2006 | 08:14 AM
unknown0001's Avatar
Default Re: starter question (sle.simon)
Starters are generally all the same except there is a difference between automatic and standard starters.
You can run a b-series starter from a 90 integra on your 94 teg and it will work fine. It's just a positive and negative connection
Old Sep 9, 2006 | 08:28 AM
sle.simon's Avatar
Default Re: starter question (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Starters are generally all the same except there is a difference between automatic and standard starters.
You can run a b-series starter from a 90 integra on your 94 teg and it will work fine. It's just a positive and negative connection </TD></TR></TABLE>
sweet so i could use any starter? as long as it came froma standard car.
Old Sep 9, 2006 | 09:18 AM
6doorsentra's Avatar
dual cam with dual cam..single with single cam..auto with auto..etc...you can use single but might have to cut leg or adjust it...find one off an older ls..might be cheaper spend no more than 40
Soichiro-son
Apr 10, 2007 09:41 AM
trianglegreg
Dec 20, 2005 06:35 AM
jdmcivicek
Nov 22, 2003 03:33 PM
Dancing is Forbidden
Feb 12, 2003 12:25 PM
