removing back emblems and wing
Old Sep 10, 2006 | 06:00 PM
vegaspartyy's Avatar
Default removing back emblems and wing
i have a 96' 2 door LS. i want to take the wing and "A" and "integra" emblems off. i see the wing has a white adhesive pad on each side where it meets the car, maybe someone who has done a clean job of removing this can tell me how, or link me somewhere, and what about the emblems?
thanks!
Old Sep 10, 2006 | 06:06 PM
atg1290's Avatar
I hope you plan to fill those holes preferably welding.... http://www.team-integra.net/se...D=528
Old Sep 10, 2006 | 06:45 PM
thanks! anyone know about the wing?
Old Sep 11, 2006 | 06:38 PM
gsr1289's Avatar
Default Re: (vegaspartyy)
uhh you could always use a heat gun to get emblems off makes it easier and wont have to use thiner to get the left over adhesive. as for the wing ur prolly gonna have to take off the trim pannel thats on the hatch and there will be some bolts. not to hard.
Old Sep 11, 2006 | 09:09 PM
rgaray's Avatar
Remove the panel under the hatch to disconnect the harness for the spoiler brake light, remove 2 nuts on each side of the hatch, then pop that SOB off.
You can also use a pice of nylon line to remove the emblems, and use WD40 or another type of thinner to remove the remaining double sided tape.
Here's what I used to cover up the holes. Pics are on pg. 2. Good luck.
http://www.team-integra.net/fo...eDESC
Old Sep 11, 2006 | 09:11 PM
Mr. green.'s Avatar
Default Re: (rgaray)
totally off topic how much do you think it would cost for a body shop to weld and paint the emblem holes on the hatch?
Old Sep 11, 2006 | 09:15 PM
rgaray's Avatar
$200-400
Old Sep 11, 2006 | 09:21 PM
Mr. green.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray &raquo;</TD></TR><TR><TD CLASS="quote">$200-400</TD></TR></TABLE>
that fast steel stuff? did you have to paint it or what? my car is black and I really want those holes filled. and any suggestions for the front emblem since the bumper is plastic?
Old Sep 11, 2006 | 09:51 PM
rgaray's Avatar
You can probably use this one
http://polymericsystems.com/quikplastik.htm
GetAwayDriver
Oct 14, 2004 02:46 PM
-BlueGSR-
May 3, 2003 09:11 AM
threatcon13
Nov 11, 2001 02:05 PM
mattymatt
Aug 3, 2001 09:07 AM
hothatch
Jun 28, 2001 01:18 AM
