idling problem.
Old Dec 30, 2006 | 12:18 PM
d3viant's Avatar
Default idling problem.
i just finished putting my b18c itr motor into my 92 integra gsr. The car starts right up and idles fine, but if you let the car sit and idle it will eventually just die. The idle goes from about 900 rpm down to about 750, then dies. i don't even know where to start.
Old Dec 30, 2006 | 01:08 PM
d3viant's Avatar
bump. drives around fine but if i come to a stop it drops idle down to about 500 rpm and will die after a few mins if you don't start moving again.
Old Dec 30, 2006 | 03:32 PM
d3viant's Avatar
bump =\.
Old Dec 31, 2006 | 12:25 AM
d3viant's Avatar
bump ... only seems to do it when its up to temperature.
Old Dec 31, 2006 | 06:53 AM
d3viant's Avatar
bump again geez.
Old Dec 31, 2006 | 07:57 AM
integrawow's Avatar
Sorry it took sooooo long! So here it goes:
Remove the iacv (don't remove the coolant hoses that attach to it, because you can clean it without removing the hoses) and spray some carburetor cleaner into your iacv screen and blow it out with compressed shop air. Your iacv may be dirty as f##k. I have had similar issues, or better yet, I am still sort of having similar issues.
See, the fitv (fast idle thermo valve) will control cold startup such as when the engine is all reved up on cold start. Then the rpm's will drop since the engine is at or near operating temp. This is where the iacv takes control of the show.
You can clean it, and this should make some sort of a difference. If you notice some sort of a difference, then replace the iacv. However, if the engine idles perfectly, just keep the old iacv, because it would be a waste of money to buy a new one if you can get the old one working right. Additionally, if you replace the entire iacv, get one from Honda/Acura parts, and not from a shitty parts store.
I hope this helps!
Old Dec 31, 2006 | 08:16 AM
crxmissing's Avatar
Default Re: (integrawow)
integrawow
I think he is right but also check all the vaccum hoses for little tiny holes
Old Dec 31, 2006 | 09:00 AM
integrawow's Avatar
Default Re: (crxmissing)
KimvdLinde
Jun 29, 2013 01:40 PM
EG9_808
18
Feb 7, 2011 10:43 AM
kUrb3d
Aug 16, 2010 11:20 AM
Eighty-Nyne
May 1, 2009 06:55 AM
