Broken with pic.
Old Dec 30, 2006 | 03:39 PM
cslegacy's Avatar
Default Broken with pic.
Theres bolts keep snaping will this be ok to run the engine like this? lose any power whats the part called to replace the hole part. Im not going to drill them all out.
Old Dec 30, 2006 | 04:06 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Broken with pic. (cslegacy)
how many are broken?
Old Dec 30, 2006 | 04:12 PM
kiddcarbuff's Avatar
dont crank them down so tight next time
Old Dec 30, 2006 | 04:17 PM
frankenstienEk's Avatar
Default Re: (kiddcarbuff)
just replace them, their about 6 bucks from the dealer and easy to replace.
Old Dec 30, 2006 | 04:33 PM
Madness's Avatar
18 90012-PM7-000 BOLT B, HEAD COVER 4 2000 INTEGRA 3.78 3.02
From Baranco Acura's website.
Old Dec 30, 2006 | 04:36 PM
-Kirk-'s Avatar
Default Re: Broken with pic. (Madness)
Once you get the valve cover off you'll be able to get the rest of it out. Only torque them back down to 8ft lbs
Old Dec 30, 2006 | 05:06 PM
cslegacy's Avatar
I cant unscrew them out becuase they are snapped off at the bottom i need to drill them out i think and im not going to do that would i need to replace teh head?
Old Dec 30, 2006 | 07:35 PM
Import_spoon's Avatar
Wow i have a broken one just like the one you have on your 3rd picture. I was like i wonder what happens if i crank it hard. I didn't mean to crank it too hard but it snap and i was like Aw hell no. So its like $6 to get it replace at the Acura/Honda dealer?
Old Dec 30, 2006 | 08:50 PM
cslegacy's Avatar
I went to honda and they gave me one for free and i cant take the old one out. do i gota fix this?
Old Dec 30, 2006 | 09:10 PM
Jay J's Avatar
Prince of Zamunda
Default Re: (cslegacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cslegacy &raquo;</TD></TR><TR><TD CLASS="quote">I went to honda and they gave me one for free and i cant take the old one out. do i gota fix this?</TD></TR></TABLE>
Take off VC, and use a wrench with a breaker bar...
Old Dec 30, 2006 | 09:19 PM
qfast817's Avatar
Default Re: (Jay J)
you have to take the valve cover off then use a 12mm to take them off
Old Dec 30, 2006 | 10:16 PM
cslegacy's Avatar
i cant take it out its round by the way so i cant use a 12mm its b18c engine
Old Dec 30, 2006 | 10:59 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cslegacy &raquo;</TD></TR><TR><TD CLASS="quote">i cant take it out its round by the way so i cant use a 12mm its b18c engine</TD></TR></TABLE>
use vice grip or sears have stud out tool. and they are 7-8ft lbs. like baby power tight.lol
Old Dec 31, 2006 | 12:34 AM
Kangolbrand's Avatar
common since! valve cover off... fine something to unscrew.
Old Dec 31, 2006 | 02:34 AM
cslegacy's Avatar
u cant unscrew it dont u understand its broken all the way down so stfu kangobrand
Old Dec 31, 2006 | 03:49 AM
__oversea's Avatar
this will help you.
https://honda-tech.com/zerothread?id=567450
Old Dec 31, 2006 | 06:00 AM
Racermech's Avatar
Default Re: (Kangpreza)
It looks like the stud in the second pic is snaped off flush with the valve cover.
Do this.
Step 1. Remove all other nut holding down the valve cover.
Step 2. Remove all hoses/grouns straps...etc from valve cover
Step 3. Remope valve cover.
Now there should be some amount of stud sticking out from the block. If so then grab a wrench and remove it (can someone confirm this will be reverse thread or std thread?)
If the stud is flush with the head then you will need to drill a small pilot hole and get an eazy out to remove the stud. You wont have to drill it all the way out just enough to get the easy out into the stud and remove it. The other thread about the exhaust manifold is perfect for doing this same thing.
If you can remove it or dont feel like you have the skills to remove I would drive very lightley to a local mechanic and ask them to do it. I would say any mechanic can do it it is a pretty basic and semi common thing to do.
Old Dec 31, 2006 | 07:33 AM
GSRNetics's Avatar
I wouldn't get mad at the people that are trying to help you. If you used some common sense, you would do what everyone is suggesting on here:
TAKE THE VALVE COVER OFF AND YOU WILL BE ABLE TO GET THE STUD OUT!!!!
Old Dec 31, 2006 | 07:38 AM
shyboi4u's Avatar
Default Re: (GSRNetics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRNetics &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't get mad at the people that are trying to help you. If you used some common sense, you would do what everyone is suggesting on here:
TAKE THE VALVE COVER OFF AND YOU WILL BE ABLE TO GET THE STUD OUT!!!! </TD></TR></TABLE>
Old Dec 31, 2006 | 09:31 AM
da_33's Avatar
Default Re: (shyboi4u)
Get it out yet?
Modified by da_33 at 10:52 AM 12/31/2006
Old Dec 31, 2006 | 09:45 AM
DA6righthand's Avatar
ask somebody else to do it snce you cant figure it out.
Old Dec 31, 2006 | 10:10 AM
92integraVTECgsr's Avatar
Default Re: (DA6righthand)
STEPS:
1. Unscrew all the nuts hold the valve cover down. 1 on each corner (4 total).
2. Unscew the nuts holding the spark plug cover on. 1 on each corner (4 total).
3. Unscrew the 4 nuts that were underneath the spark plug cover on the same studs (4 total).
There should be 12 all together. Once they are all removed, you can remove the valve cover and see the studs.
There is a place where you can put a 10mm socket over the stud and unscrew it from the head. They are all like that. They are easy to replace.
If you can't understand or do it after all the help that has been given in this post, please, do not make any other post until you search and read a little bit and get some clue as to what you are doing.
This is VERY simple and has been explained as easy as possible. You dont have to be a Doctor to take the valve cover off.
Old Dec 31, 2006 | 10:11 AM
Default Re: (92integraVTECgsr)
TAKE A PICTURE of your whole valve cover and post it on here. Make it bigger then the original pics you posted.
Old Dec 31, 2006 | 11:16 AM
Sam92Teg's Avatar
Taking a picture of the valve cover doesn't help, he needs to take one with the valve cover off so everyone can see where the studs are broken at. If the studs somehow are broken flush with the head, then most of the advice on this thread is useless (besides Racermech's advice). They will need to be drilled out and an extractor used or reverse thread drill bit.
In the first pic, the studs can't be seen, so they might have broken off flush with the head, but on the second pic, the stud is clearly seen and shouldn't be a problem to remove.
Old Dec 31, 2006 | 11:48 AM
qfast817's Avatar
Default Re: (Sam92Teg)
the valve cove is not the head,
here a link to a pic of the studs with the 12mm
http://www.team-integra.net/se...=1049
