brake problem.
Old Dec 31, 2006 | 04:18 PM
jikespingleton's Avatar
Default brake problem.
so after i did the motor swap on the car, my brake pedal feels as if the car isnt runnin. u known when u hit ur brakes when the car isnt runnin and they are really stiff. thats how they are when i drive. is the master cylinder not gettin enough engine vaccum? do i need to bleed the system?
Old Dec 31, 2006 | 05:58 PM
Default Re: brake problem. (jikespingleton)
anyone?
Old Jan 1, 2007 | 07:05 AM
Dogginator's Avatar
Daisy... Daisy...
I say that the brake booster is not getting proper vacuum or it is faulty. If the brakes needed to be bled, the pedal would be spongy. Do your brakes work normally besides the increased pedal effort?
Old Jan 1, 2007 | 11:39 AM
Default Re: brake problem. (Dogginator)
they dont work at all pretty much. i have to stomp on it to make it stop a lil. i was also thinkin the master cylinder and or brake booster wasnt gettin enough vaccum. how do i check that?
Old Jan 1, 2007 | 11:46 AM
Dogginator's Avatar
Daisy... Daisy...
You can physically check the vacuum line from the intake manifold to the brake booster. Try disconnecting the vacuum line (block it with tape or a plug to prevent excess air from entering the intake manifold) and seeing if the pedal effort changes at all.
Does your braking power increase if you pump the pedal? Does the pedal sink if you apply the brakes for any length of time?
Old Jan 1, 2007 | 11:59 AM
no breakin power doesnt increase when i pump the pedal. ill try checking the vaccum lines first because im sure theres a line i didnt hook up after i did the swap.
Old Jan 1, 2007 | 02:20 PM
yup the vaccum line is connected to the manifold and brake booster and the problem is still there. wat shouldl i do?
Old Jan 1, 2007 | 04:50 PM
Dogginator's Avatar
Daisy... Daisy...
Inspect the check valve (part 7). Does the booster make any sucking noise associated with an idle speed increase when the brake pedal is released?
Old Jan 1, 2007 | 05:21 PM
asianpoet's Avatar
bump cause I would also like to know..
Old Jan 2, 2007 | 01:31 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
did you swap out your bb/mc?
kazaa187
May 26, 2013 01:51 PM
4DoorCivic1
Jun 4, 2012 08:43 PM
Del_Sol_s
27
Mar 4, 2006 06:49 AM
MrEg
Sep 22, 2003 04:49 PM
veejay
Jul 24, 2001 09:39 AM
