dizzy problem
Old Jan 2, 2007 | 10:54 PM
Extreez's Avatar
Default dizzy problem
Hey, i got a 1993 Integra and today i found a problem that just got worst from time, the distrubotor makes a really annoying and loud grinding and cracking noise while the car is on/idling or driving i was wondering can this just be spark plug wires ? or a fixable problem on the dizzy ? or just need a new distrubutor ?
Old Jan 2, 2007 | 10:57 PM
PrinceAli132's Avatar
Default Re: dizzy problem (Extreez)
It kind of sounds like the rotor screw came off inside. Take the cap off and check to see whats going on inside.
How-to replace cap and rotor;
http://www.team-integra.net/se...D=393
Basically follow the steps to remove the cap and to see if the rotor screw is flying around inside.
Ali
Old Jan 2, 2007 | 10:58 PM
Extreez's Avatar
Default Re: dizzy problem (PrinceAli132)
i opened it it wasnt flying anywhere inside.... unless if i have to take the steel plated cap off too.
Old Jan 3, 2007 | 07:41 AM
95 integra's Avatar
Try a new distributor.
Old Jan 3, 2007 | 11:29 AM
Sam92Teg's Avatar
Default Re: dizzy problem (95 integra)
If it isn't the rotor, then it is probably the shaft bearing in the distributor, but usually you will see excessive wear on the rotor and cap terminals.
Old Jan 3, 2007 | 11:41 AM
SimplyB18C1's Avatar
Yeah check the shaft bearing. Is there any rust build up on it or any play?
Old Jan 3, 2007 | 04:33 PM
Extreez's Avatar
Default Re: (SimplyB18C1)
major rust, replaced.
rayzian
Dec 8, 2007 02:50 PM
JWilley
Jan 26, 2007 12:17 PM
92 CIVIC HATCH VX
Apr 12, 2006 09:58 AM
TJSUPE
Jun 26, 2004 11:48 AM
89 CRX SI
Apr 14, 2003 07:49 PM
