need quick help with ignition switch!!!!!
Old Jan 3, 2007 | 10:04 AM
vbspunger's Avatar
Default need quick help with ignition switch!!!!!
I have a 94 ls and the ignition switch went bad (car would start but when the key was released to the on position, car would die) so i put my new one in and now i dont get anything when I turn the key, the car wont even turn on. NOT A DAMN THING
Any suggestions.
Modified by vbspunger at 12:09 PM 1/3/2007
Old Jan 3, 2007 | 10:13 AM
8YourV8's Avatar
Default Re: need quick help with ignition switch!!!!! (vbspunger)
sounds like a dizzy/plug problem, not an ignition switch problem.
and when you connected your new switch you probably forgot to connect a ground wire or something.
Old Jan 3, 2007 | 10:20 AM
vbspunger's Avatar
it is not a dizzy or plug problem. I could keep the car running by holding the key just past the on position. and everything for the switch is plugged up.
Old Jan 3, 2007 | 11:21 AM
vbspunger's Avatar
please!!!
badfish2282
May 15, 2009 08:45 PM
b00sted4dr
Jul 31, 2006 05:14 PM
b00sted4dr
Jul 31, 2006 05:00 PM
BlkGSR
Mar 7, 2004 06:28 AM
