normal idling whe cold?
Old Jan 3, 2007 | 10:01 PM
-Championship-'s Avatar
Default normal idling whe cold?
i recently cleaned the iacv and now when i crank it up in the mornings, the rpm is at 1200-1300 when cold?..and takes longer to warm up?....
Old Jan 4, 2007 | 06:49 AM
WalkerGSR1's Avatar
My car is at 1500 rpm when cold its a 200 integra. When it warms up drops to 750 rpm. Did you disconnect your battery to reset everthing?
Old Jan 4, 2007 | 07:43 AM
95 integra's Avatar
Default Re: (WalkerGSR1)
Depends on the temp out. If its rather cold, then 1800, moderate (say 40-55ish) then around 1500 and anything above that is like 1200 or below.
Old Jan 4, 2007 | 07:47 AM
ac_attak's Avatar
Default Re: normal idling whe cold? (CW_98gsr)
Here where i am its usually below 0 degrees so when i first start it idles at probably 1800 or so.
Old Jan 4, 2007 | 06:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">My car is at 1500 rpm when cold its a 200 integra. When it warms up drops to 750 rpm. Did you disconnect your battery to reset everthing?</TD></TR></TABLE>
yeah i did, i had to raise my idle on the TB
when warm it idles at 800 or so, and when the temp is at 50 or 60 it starts up at 1200-1300
just wondering if that's bad
Old Jan 4, 2007 | 07:58 PM
95 integra's Avatar
Default Re: (CW_98gsr)
That sounds about right for that temp to me. If its colder out then it should be a bit higher.
jdm_eg06
11
Feb 10, 2007 07:23 PM
Sic_DA_Nine
Jun 16, 2006 11:14 PM
00-501itrspec
Nov 17, 2005 04:25 AM
b18c1delly
Aug 12, 2002 07:19 AM
SoloSol
Dec 26, 2001 07:06 PM
