o2 sensor help!?
Old Dec 31, 2006 | 03:52 AM
Nathavat's Avatar
Default o2 sensor help!?
hey i just recently installed my apex ws2 like couple days ago. the check engine light has been on. and now my speedometer doesnt even work. it doesnt show how fast im going. please help with some info. sorry for the newb question.
Edit: o yea. i have a 00 gsr also with K&N intake. Im thinking its the o2 sensor from the cat. i think i might have tugged on the wire a bit. might have messed it up. not really sure.
Modified by Nathavat at 5:04 AM 12/31/2006
Old Dec 31, 2006 | 08:15 AM
Tizight's Avatar
what codes is it throwing?
Old Dec 31, 2006 | 12:53 PM
Nathavat's Avatar
Default Re: (Tizight)
codes? im not sure how do i check?
Old Dec 31, 2006 | 01:03 PM
ac_attak's Avatar
Default Re: (Nathavat)
You use an obd2 code reader. Just take it to a shop or autozone and get them to scan it for you.
Old Dec 31, 2006 | 01:07 PM
Nathavat's Avatar
Default Re: (ac_attak)
ic. so i can take it to autozone and ask them to scan my car? or will i have to do it.
Old Dec 31, 2006 | 01:26 PM
Fat Chick Magnet's Avatar
it could be another problem. my clusters stopped working after my distributor went bad.
Old Dec 31, 2006 | 04:26 PM
Nathavat's Avatar
Default Re: (dc2rtek)
i think its cuz i pulled the o2 sensor alil bit when i was messing with the cat. the o2 sensor wire that goes into the car must have either ripped or came loose.
Old Dec 31, 2006 | 04:45 PM
no2unenolife's Avatar
do you have a check engine light?
Old Dec 31, 2006 | 07:49 PM
ac_attak's Avatar
Dont just guess what it is, thats why cars have check engine lights. They will scan the ecu for you at autozone and will be able to tell you what the problem is.
Old Jan 1, 2007 | 07:14 AM
Tizight's Avatar
I PM'd you a link
Old Jan 2, 2007 | 04:04 PM
Nathavat's Avatar
hey i got it checked. looks like i need a new o2 sensor for my cat. i was wondering if this will effect my performance? i heard if the check engine light is on sometimes the car will run on safe mode? is this true? what should i do replace the o2 sensor or leave it. money is kinda tight right now so yea.
Old Jan 2, 2007 | 07:22 PM
ac_attak's Avatar
Default Re: o2 sensor help!? (Nathavat)
Do you have a high flow cat?
Old Jan 3, 2007 | 03:29 AM
Nathavat's Avatar
Default Re: o2 sensor help!? (ac_attak)
no stock cat
Old Jan 3, 2007 | 09:09 AM
Topher.'s Avatar
Some cars run into limp mode when they throw a code.
I forget which codes exactly will cause your car to do this but Ive been running on a CEL for O2 sensor for a year now and I've never had a problem. (My test pipe's O2 bung is out of reach for the sensor)
It's running a bit rich so I'm sure performance is hindered slightly but nothing drastic.
Old Jan 3, 2007 | 10:18 AM
Nathavat's Avatar
Default Re: o2 sensor help!? (B92P_DC2)
man... it is not my year. now guess what. i was driving home last night and my power went out slowly. first it was my radio, then my head lights, then finally died infront of my house. i think it might be my altenator. any one wanna take a stab??
Old Jan 3, 2007 | 10:22 AM
Nathavat's Avatar
does anyone know how much this will cost if i do have to replace my altenator??
young geezer
May 25, 2010 07:02 PM
Amused
May 9, 2006 06:59 AM
civicd16ex
Jan 22, 2006 04:18 PM
laokorn
Aug 18, 2003 03:56 PM
turrismaldon
Jun 19, 2002 05:55 AM
