help with annoying speedometer cable
Old Jan 2, 2007 | 04:40 PM
norcal450's Avatar
Default help with annoying speedometer cable
my 90 inetgra LS with 223K miles has developed an annoyingly loud rattle/squel/squeak that i am pretty sure is coming from my speedo cable.
i took it to the dealer but they of course want too much $$$
so any idea on how to lube the cable or even disable it? i have had the car so long that im really good at knowing roughly how fast im going by what gear im in compared to rpm's
Old Jan 2, 2007 | 07:24 PM
RedEj8's Avatar
Default Re: help with annoying speedometer cable (norcal450)
see if you can take it apart and spray some wd40 in it
Old Jan 3, 2007 | 09:57 AM
norcal450's Avatar
Default Re: help with annoying speedometer cable (RedEj8)
ya i was thinking that might work. does anyone have a writeup or how to on accessing the speedo cable before i start ripping apart my dash?
Old Jan 3, 2007 | 11:13 AM
Sam92Teg's Avatar
G2IC.com has a write-up. You don't need to 'rip apart the dash'. You disconnect the cable from the tranny end, pull the cable out of the casing, clean, then relube with something better than WD40. Then reinsert into casing and push towards the firewall to reseat into the VSS. Go search for the write-up to be certain how because I am going off memory with limited brain capacity.
Old Jan 5, 2007 | 03:10 PM
youknowimwhite's Avatar
does it sound like it could be your wheel bearing because i sort of have the same thing your explaining and thought it could be the wheel bearing but there is no wobbly feeling and my speedo jumps sometimes changing the sound of the squeeking
philkehn
Nov 19, 2006 10:08 AM
meseetree
Jun 2, 2006 07:19 AM
jcrou
Dec 17, 2004 08:56 AM
drjondurst
Mar 29, 2003 06:34 PM
