worth it?
Old Dec 30, 2006 | 04:05 PM
B18c1vicrx's Avatar
Default worth it?
b17 motor running strong, ctr pistons, mugen head gasket, stock tranny-no grinds...$2000....thoughts on that? thanks.
Old Dec 30, 2006 | 05:55 PM
Sam92Teg's Avatar
Default Re: worth it? (grod)
You can get a JDM low mileage B16a full swap mated to a low mileage cable tranny with limited slip diff for less than that price from HMOnline. The B17 is kinda rare tho, so if you have a 2nd gen integra that came with one, maybe that could sway your decision.
Old Dec 30, 2006 | 05:58 PM
DC2 Mang's Avatar
if you already have a car with a b-series engine in it then you can buy a gsr longblock for cheaper, it will be stock, un-modified, and probably come with a warranty
you never know how the person built or treated the b17
Old Dec 30, 2006 | 07:59 PM
B18c1vicrx's Avatar
Default Re: worth it? (DC Mang)
actaully the motor belongs to a friend of mine, the compression of two of its cylinders were low and it was still keeping up with stock ebp's, but thats with h/i/e, and he believes its the pistons that are the problem in those cylinders, thats why he got the ctr cams...yay/nay?
Old Dec 30, 2006 | 09:34 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grod &raquo;</TD></TR><TR><TD CLASS="quote">actaully the motor belongs to a friend of mine, the compression of two of its cylinders were low and it was still keeping up with stock ebp's, but thats with h/i/e, and he believes its the pistons that are the problem in those cylinders, thats why he got the ctr cams...yay/nay?</TD></TR></TABLE>
he got the ctr cams because it pulled low compression in 2 cylinders?
it sounds to me like the rings did not seat as well as the other 2 cylinders, which may cause problems later on down the road
Old Dec 31, 2006 | 05:53 AM
B18c1vicrx's Avatar
new rings as well...
Old Dec 31, 2006 | 10:20 AM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grod &raquo;</TD></TR><TR><TD CLASS="quote">new rings as well...</TD></TR></TABLE>
they still may have not broken in and seated properly
Old Dec 31, 2006 | 12:58 PM
B18c1vicrx's Avatar
alright well here is the exact scenario...the motor has the two bad cylinders now without the pistons in yet. I have been told that i will be receiving the motor with 4 cylinders running at whatever the compression is suppose to be and thats with the ctr pistons installed...i just want to know that the motor will be fine in the future if this seals the problem.
Old Dec 31, 2006 | 01:01 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grod &raquo;</TD></TR><TR><TD CLASS="quote">alright well here is the exact scenario...the motor has the two bad cylinders now without the pistons in yet. I have been told that i will be receiving the motor with 4 cylinders running at whatever the compression is suppose to be and thats with the ctr pistons installed...i just want to know that the motor will be fine in the future if this seals the problem.</TD></TR></TABLE>
if the damaged cylinders are not honed or bored over properly then yes you will run into major porblems
my advice is to invest your money into a stock engine and from there do the work yourself
Old Jan 1, 2007 | 11:17 AM
B18c1vicrx's Avatar
would it make any difference if i got it bored out right myself
Old Jan 1, 2007 | 06:21 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: (grod)
it sounds like you already have your mind made up what you are going to buy, people said you can get a more reliable swap for cheaper
Old Jan 1, 2007 | 07:03 PM
B18c1vicrx's Avatar
yeah, i already got a setup going, as of now its gonna be a b17 in a crx body with headers, intake, exhaust, itr intake manifold, ctr pistons, port and polished, springs and retainers for now then a little hondata and tuning...
94typeR
May 26, 2007 11:59 AM
Jago
Jan 8, 2007 09:36 PM
jeremy.
199
Dec 23, 2004 03:45 PM
TypeR II
Jul 22, 2004 08:19 PM
nmhybridog
Sep 24, 2003 07:27 AM
