code 14 (iac)
Old Dec 31, 2006 | 12:40 PM
jikespingleton's Avatar
Default code 14 (iac)
wat is an idle control valve and why would i be throwing that code?
Old Dec 31, 2006 | 12:53 PM
boostdcivicgsr96's Avatar
Default Re: code 14 (jikespingleton)
Idle control valve is what controls the idle on your car... it is located on the back of your intake manifold. try taking it off and cleaning it out with some carb clean or parts cleaner let it dry and put it back on then disconnect your neg terminal on your battery and leave off for a few minutes to reset your computer then try starting it back up let it idle and see if that fixes your problem.... good luck
Old Dec 31, 2006 | 02:10 PM
Default Re: code 14 (boostdcivicgsr96)
well its the iac on the ls motor. is in the same location?
Old Dec 31, 2006 | 02:44 PM
PrinceAli132's Avatar
***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve ;
https://honda-tech.com/zerothread/1575913
Ali
HIBOOST101
Jul 18, 2007 04:58 AM
Creepshow S60
Aug 29, 2004 06:36 PM
Glocked1
12
Jan 22, 2004 08:13 PM
BLKCRX
Nov 11, 2002 07:05 PM
