square motor
Old Jun 23, 2007 | 08:57 AM
SleeperGSR's Avatar
Default square motor
I heard something about this from an old timer. We were BSing about car and he started talking about square motors where the stroke=bore. I was wondering if anyone has done this with hondas and what the bennefits would be.
Old Jun 23, 2007 | 09:15 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: square motor (SleeperGSR)
The B16s are close.
Old Jun 23, 2007 | 09:30 AM
SleeperGSR's Avatar
Default Re: square motor (Dogginator)
what about for a gsr motor? that's how we got talking about it
Old Jun 23, 2007 | 09:37 AM
Dogginator's Avatar
Daisy... Daisy...
The B17A is practically a square engine.
This link has some B-series bores and strokes.
http://g-speed.com/pbh/b16a/index.html
Old Jun 23, 2007 | 10:05 AM
dohcMONSTER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">what about for a gsr motor? that's how we got talking about it</TD></TR></TABLE>
GSR motor is 81x87.2
LS motor ia 81x89
Old Jun 23, 2007 | 10:20 AM
numbnuts22715's Avatar
b17 is 81 X 81.4
thats realllly close.
Old Jun 23, 2007 | 10:27 AM
SleeperGSR's Avatar
Default Re: square motor (dohcMONSTER)
so i'm pretty new to engine tuning, i'm trying to read up as much as possible. From a reliablitly point of view i'm thinking it would be better to increase the bore rather than the stroke for the maximum hp/reliablity gain. i'm going to work on the b18c1. Is this thinking correct?
Old Jun 23, 2007 | 11:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">so i'm pretty new to engine tuning, i'm trying to read up as much as possible. From a reliablitly point of view i'm thinking it would be better to increase the bore rather than the stroke for the maximum hp/reliablity gain. i'm going to work on the b18c1. Is this thinking correct?</TD></TR></TABLE>
depends what your power goal is, how much money you have to spend etc. plenty of reliable 200+whp motors have been built on stock sleeves and bore/stroke
Old Jun 23, 2007 | 11:55 AM
SleeperGSR's Avatar
looking for 200-250whp. i would like to see a good torque gain also. I would like to try to flatten out the power curve and get more acceleration but not to much more top speed. I know this can be done with a 16a tranny. but i want a built motor also. And it's old so i would like to clean everything up, that why i was thinking bore and hone with jdm type r pistons. stage 1 skunk cams and a few other things along with a good tune.
Old Jun 23, 2007 | 12:15 PM
doood's Avatar
been there done that
k20a's are square. 86x86.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">looking for 200-250whp. i would like to see a good torque gain also. I would like to try to flatten out the power curve and get more acceleration but not to much more top speed. I know this can be done with a 16a tranny. but i want a built motor also. And it's old so i would like to clean everything up, that why i was thinking bore and hone with jdm type r pistons. stage 1 skunk cams and a few other things along with a good tune.</TD></TR></TABLE>
for that power goal, consider an 85x87.2/89 setup
Old Jun 23, 2007 | 12:34 PM
SleeperGSR's Avatar
Default Re: square motor (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">k20a's are square. 86x86.
for that power goal, consider an 85x87.2/89 setup</TD></TR></TABLE>
So i can bore a stock b18c1 block out to 85?
Old Jun 23, 2007 | 12:45 PM
doood's Avatar
no you need to sleeve first
Old Jun 23, 2007 | 01:00 PM
SleeperGSR's Avatar
yeah i'm a noob.....i always thought a sleeve was bolted between the block and the head? what exactly are you talking about
Old Jun 23, 2007 | 01:04 PM
doood's Avatar
https://honda-tech.com/zerothread?id=565375&page=1
Old Jun 23, 2007 | 01:16 PM
SleeperGSR's Avatar
ok i'm starting to get it...so if i do any work to the block i will probably need a larger sleeve?
Old Jun 23, 2007 | 01:19 PM
doood's Avatar
not really. just depends on your power goals and budget. you can safely overbore to 82mm on stock sleeves. but that's pushing it a little. stock is 81mm.
there's no replacement for displacement, and that certainly holds true for our little 4 bangers.
Old Jun 23, 2007 | 01:25 PM
SleeperGSR's Avatar
so going larger than 1mm overbore would require extensive work and machining
Old Jun 23, 2007 | 01:27 PM
doood's Avatar
that's when resleeving comes into play
Old Jun 23, 2007 | 01:29 PM
SleeperGSR's Avatar
thanks man....is this something you have done. How much does this run?
Old Jun 23, 2007 | 01:31 PM
doood's Avatar
havent done it personally but it's in my long term plans. expect a good sleeve job from any of the top company's out there to run you at least $900.
http://www.goldeneaglemfg.com
http://www.erlperformance.com
http://www.laskeyracing.com
just a few for you to look at
Old Jun 23, 2007 | 02:08 PM
SleeperGSR's Avatar
so if i went with a .5mm overbore just to clean up the stock sleeve, type r pistons ballance crank. then did some work on the head. Port polish, valves, springs, cams. i would be getting close to 9 on the tach and around 200 hp?
Old Jun 23, 2007 | 02:34 PM
doood's Avatar
depends entirely on the setup
Old Jun 23, 2007 | 02:55 PM
SleeperGSR's Avatar
well i'm on the right track anyway?
Old Jun 23, 2007 | 04:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">so if i went with a .5mm overbore just to clean up the stock sleeve, type r pistons ballance crank. then did some work on the head. Port polish, valves, springs, cams. i would be getting close to 9 on the tach and around 200 hp?
yes essentially you would. here is an example, this is my old set-up
GSR motor
82x87.2
CTR pistons
CTR crank pulley
Blox HSL cams
Blox intake manifold
pro fab header
tuned on hondata s200
AEM ITR cold air
netted me 225/155
so yes you are on the right track, now just spend time researching parts and what would work best for you
KillaEj1
17
Nov 9, 2008 12:22 PM
PHILEE
May 9, 2008 11:50 AM
EG type GTR
Aug 5, 2006 11:36 PM
Nytemare
Feb 22, 2005 05:13 PM
