VTEC CONTROLLERS INFO
Old Jun 23, 2007 | 12:36 PM
g0tgot's Avatar
Default VTEC CONTROLLERS INFO
what exactly is the benefit of having a vtec controller.............having the vtec kick in before someone elses vtec? is it better than I-VTEC? please educate a fool!
Old Jun 23, 2007 | 01:05 PM
doood's Avatar
been there done that
Default Re: VTEC CONTROLLERS INFO (g0tgot)
http://www.phearable.net/tech/....html
http://auto.howstuffworks.com/question229.htm
http://asia.vtec.net/article/k20a/
Old Jun 23, 2007 | 01:16 PM
g0tgot's Avatar
ok but as far as adjusting when you want your vtec to kick in.....can you set a b20vtec motor to be pretty much the same as a k20?
Old Jun 23, 2007 | 01:20 PM
doood's Avatar
Default Re: (g0tgot)
every engine is going to be different. each will want vtec at a different point based on the cams. a b20vtec can never be pretty much like a k20 simply because k20's have i-vtec and there's no way to retrofit this system onto a b series.
Old Jun 23, 2007 | 07:58 PM
martyball619's Avatar
Default Re: (doood)
vtec controller is whack. its to use when u r tuning your motor..
cams, IM) but others use crome or hondata to maximize hp out of their engines rather than vafc
Old Jun 23, 2007 | 11:34 PM
da9blk1's Avatar
Default Re: (DC2SiR)
its not good to change where vtec begins, right?
Old Jun 24, 2007 | 12:02 AM
Dartanian's Avatar
Default Re: (da9blk1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot &raquo;</TD></TR><TR><TD CLASS="quote">ok but as far as adjusting when you want your vtec to kick in.....can you set a b20vtec motor to be pretty much the same as a k20?</TD></TR></TABLE>
You set vtec where the low cam and high cam torque curves intersect, not based on a completely different engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da9blk1 &raquo;</TD></TR><TR><TD CLASS="quote">its not good to change where vtec begins, right?</TD></TR></TABLE>
Only if the powerband benefits from it. For stock cams, moving vtec around is only going to cost power.
Old Jun 24, 2007 | 01:10 PM
guezroks's Avatar
god it seems that now a days every one is full of misinformation. good luck to us all. vtec controller is simply used to tune your engine when substantial amounts of mods are acquired, that might include changing your vtec crossover point, whether it'd be raising or lowering the vtec point
Old Jun 24, 2007 | 01:12 PM
guezroks's Avatar
vafc - Vtec Air Fuel Controller.. helps in tuning your Air/Fuel ratios
doood's Avatar
Default Re: (guezroks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guezroks &raquo;</TD></TR><TR><TD CLASS="quote">vafc - Vtec Air Fuel Controller.. helps in tuning your Air/Fuel ratios</TD></TR></TABLE>
in a very crude manner
delsol6386
Apr 6, 2004 07:05 AM
ty_racer
Acura TL, RL & ZDX
Mar 12, 2004 06:47 PM
jessevtec
Sep 24, 2003 12:00 PM
300zxTT
May 27, 2003 10:29 AM
The_Brian
Jul 15, 2002 10:09 PM
