engine?
Old Jun 21, 2007 | 04:11 PM
racereaper7's Avatar
Default engine?
i have a 95 integra ls and i want to know what would be the best way of going
b18c1 gsr
b16a2
ls/vtec (heard good things and bad things)
boost the b18b1 engine i have already
-the ls vtec is something i have always wanted to do but i heard it costs a lot and there is a lot of blown engines and engine damage.
your input would be great.
thanks for your help.
Old Jun 21, 2007 | 04:28 PM
Rikter's Avatar
Drop a 305 in there.
Maybe if you weren't a complete tard you'd tell us something like what you want your car to be.
-Rik
Old Jun 21, 2007 | 04:32 PM
IAcivicEK's Avatar
Banned
lol^^^
Depending on the shape of your b18b, I would suggest boosting it. It seems to be the easiest out of those you chose.
Old Jun 21, 2007 | 04:34 PM
posHonda's Avatar
SEARCH SEARCH SEARCH
you need to give us a more detailed description on what YOU want. power goals, budget? boosting your stock motor will give you the best results for the least amount of money.
Old Jun 21, 2007 | 05:15 PM
Default Re: (iVteC_PoWeR)
i would like it to be a daily driver that has power behind it. not a whole lot of money but i could find enough. sorry for that i forgot to say what i wanted to do. something that packs power but is a daily driver. whats a 305? thanks for the help
Old Jun 21, 2007 | 05:27 PM
posHonda's Avatar
a 305 is a big block thats obviously not compatible for an integra. i think an LS turbo doing 250-300whp will do fine for you. that is attainable on stock internals. make sure your motor is healthy first or KA BOOM!
Blahblah718293's Avatar
Default Re: (racereaper7)
i think the 305 is a chevy V8.
Old Jun 21, 2007 | 05:28 PM
numbnuts22715's Avatar
id boost it!
Do a compression test and if it checks out go ahead with the boosting, if not, build it up for around 3k, then boost the ever living **** out of that.
Old Jun 21, 2007 | 05:36 PM
Default Re: (numbnuts22715)
it has 144,000 miles on it.
what would i do when boosting.
what turbo kit brand should i go with.
Old Jun 22, 2007 | 05:35 AM
how much does a compression test cost
Old Jun 22, 2007 | 05:56 AM
deftonerider's Avatar
a 305 is a chevy SMALL block, BIG blocks start somewhere in the 400 ci range.
compression checks are easy and you could do it yourself
Old Jun 22, 2007 | 07:02 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (deftonerider)
h2b shawty.
Old Jun 22, 2007 | 09:14 AM
ef_hatchback's Avatar
Default Re: engine? (racereaper7)
hella with ls/vtec.
i would just either go gsr or actually b16
Old Jun 22, 2007 | 09:28 AM
b20powereDA's Avatar
Default Re: engine? (ef_hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftonerider &raquo;</TD></TR><TR><TD CLASS="quote">a 305 is a chevy SMALL block, BIG blocks start somewhere in the 400 ci range.
compression checks are easy and you could do it yourself</TD></TR></TABLE>
damn it. u caught it before me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_hatchback &raquo;</TD></TR><TR><TD CLASS="quote">hella with ls/vtec.
i would just either go gsr or actually b16</TD></TR></TABLE>
ud rather go b16 over ls/vtec? are u high right now? once u get off that high come back and state something sensible. thanks
Old Jun 22, 2007 | 09:43 AM
yjischoking's Avatar
Default Re: engine? (b20powereDA)
cubic inch doesn't determine whether big or small block either. new z06 is a 427 small block.
Old Jun 22, 2007 | 10:25 AM
i was thinking the b16a2 too because my brother did that engine swap on his civic so he would know what is needed. plus it is cheaper than the gsr. gsr is better but the b16a2 is cheaper.
thanks for all your guys help.
Old Jun 22, 2007 | 11:31 AM
OC Geezer's Avatar
You could get the B16 and always rebuild it with new parts.
Just boost the LS on like 8 PSI. That should hold up nicely.
Old Jun 22, 2007 | 12:42 PM
Default Re: (InLtegSra94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yjischoking &raquo;</TD></TR><TR><TD CLASS="quote">cubic inch doesn't determine whether big or small block either. new z06 is a 427 small block.</TD></TR></TABLE>
i know that i was just stating that the 350 is a chevy SMALL block
Old Jun 22, 2007 | 02:44 PM
doood's Avatar
been there done that
https://honda-tech.com/zerosearch
seriously it's not hard to use. all of your questions can be answered by simply using it.
Old Jun 27, 2007 | 06:27 AM
and i was saying that big blocks start in 400 ci but not always it has more to do with the block design but WHO GIVES A S#IT
RighteousRyano
Aug 17, 2006 12:21 PM
Turdbocharged
Jul 30, 2005 08:28 AM
LU
Feb 21, 2005 05:56 PM
silver5spd
Feb 22, 2003 11:00 PM
