head compression test
Old Jun 21, 2007 | 12:08 PM
krazeenoy's Avatar
Default head compression test
i did a head compression test on my 93 integra....it came out to be 40 40 60 60.....what could that be?
Old Jun 21, 2007 | 12:15 PM
TurboGS-R's Avatar
Default Re: head compression test (krazeenoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazeenoy &raquo;</TD></TR><TR><TD CLASS="quote">i did a head compression test on my 93 integra....it came out to be 40 40 60 60.....what could that be?</TD></TR></TABLE>
I'm not sure because I'm not a mechanic and I can't see the car, but I would guess something inside the block, perhaps valves or piston rings.
Old Jun 21, 2007 | 12:17 PM
doood's Avatar
been there done that
Default Re: head compression test (TurboGS-R)
with numbers like that the engine shouldnt even be running
did you do the test with the engine up to temp, all plugs removed, ecu fuse removed, throttle fully opened?
Old Jun 21, 2007 | 12:23 PM
posHonda's Avatar
yea make sure you do it properly because those numbers are horribly low
Old Jun 21, 2007 | 01:42 PM
alexisthemovie's Avatar
completely fubar head gasket?
Old Jun 21, 2007 | 06:36 PM
krazeenoy's Avatar
Default Re: (alexisthemovie)
i changed the head gasket...the old head gasket was in good condition.....the car doesnt run...just cranks and yes i did the compression test properly.....i was thinking it was the head?...i dont know though...does anyone think my valves are bent?
Old Jun 21, 2007 | 09:46 PM
krazeenoy's Avatar
Default Re: (krazeenoy)
bump..anyone can give me some ideas??
Old Jun 21, 2007 | 11:19 PM
did you do something catastrophic? like a bad misshift.
Old Jun 22, 2007 | 12:03 AM
maomaniarocks's Avatar
If the procedure was done correctly and those numbers are right.... Dude you need a new engine.
Old Jun 22, 2007 | 12:10 AM
Championship's Avatar
Default Re: head compression test (maomaniarocks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maomaniarocks &raquo;</TD></TR><TR><TD CLASS="quote">If the procedure was done correctly and those numbers are right.... Dude you need a new engine.</TD></TR></TABLE>
x2
Old Jun 22, 2007 | 12:17 AM
krazeenoy's Avatar
Default Re: head compression test (Championship)
so changing the head wouldnt work at all?
Old Jun 22, 2007 | 12:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazeenoy &raquo;</TD></TR><TR><TD CLASS="quote">so changing the head wouldnt work at all?</TD></TR></TABLE>
you need to find out what the hell is up.
take off the head and find out, im shure it wont be a pretty sight.
so what in gods name happened to the motor?
Old Jun 22, 2007 | 12:26 AM
1.8L_allmotormilitia's Avatar
[QUOTE=krazeenoy40 40 60 60[/QUOTE]
sorry, but thats so low. ummmmm probably piston rings are done, valve seals, head gasket...anything.
Old Jun 22, 2007 | 12:28 AM
krazeenoy's Avatar
Default Re: head compression test (1.8L_allmotormilitia)
i took the head off already to change the headgasket...it looked normal....so i was thinking its the head...just wanted som ideas of what it could be...i bought the car like this for a price you cant even pass....so its kinda like a project now....
Old Jun 22, 2007 | 12:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazeenoy &raquo;</TD></TR><TR><TD CLASS="quote">i took the head off already to change the headgasket...it looked normal....so i was thinking its the head...just wanted som ideas of what it could be...i bought the car like this for a price you cant even pass....so its kinda like a project now....</TD></TR></TABLE>
looks fine?....get a new headgasket, redo the test and post up the results
Old Jun 22, 2007 | 12:37 AM
krazeenoy's Avatar
i just bought the headgasket...brand new out of the package lol...i guess i mite grab a new motor...probably going to try the head first...
Old Jul 2, 2007 | 10:44 PM
Get a another engine with a good compression on each cylinder 230-250 psi. A new head work make a difference because of the compression is still to low. Lose performance.
Old Jul 2, 2007 | 11:00 PM
sPaRk'iT's Avatar
Do a leakdown test and it will show you where the problem is coming from.
Old Jul 3, 2007 | 02:49 AM
Doostur's Avatar
Default Re: head compression test (doood)
[QUOTE=doood]with numbers like that the engine shouldnt even be running
QUOTE]
I told you krazee....
Old Jul 3, 2007 | 06:39 AM
deftonerider's Avatar
did you add some oil in every cylinder after do the test, that can determine if the rings are bad, then do a leakdown test to determine if its in the valves
MikeD21
Engine Machining & Assembly
14
Jan 3, 2019 10:54 AM
wayneDOHC
Sep 18, 2013 03:39 AM
94_civic_tuner
Oct 10, 2007 02:00 PM
BLK99VTECR
Dec 25, 2005 09:27 PM
eg crunkmonster
Mar 31, 2003 08:29 AM
