possible VSS problem?
Old Jun 19, 2007 | 08:15 PM
odogg726's Avatar
Default possible VSS problem?
Sup y'all. OK, here we go.
I changed out the original tranny on my GSR with another GSR tranny, and since then the speedometer, odometer and trip meter stopped working, and VTEC dissapeared as well. Helms said to check the fuse before anything, so I switched it out, and the trip meter, odometer and vtec came back, but the speedometer would act wacky, bouncing around whenever i revved passed 4. Any ideas? Thnx in advance.
Old Jun 19, 2007 | 08:39 PM
odogg726's Avatar
Default Re: possible VSS problem? (odogg726)
n e one?
Old Jun 19, 2007 | 11:26 PM
Dc2Point2's Avatar
Did you short something out? My friend had a similar problem he shorted something out changing his distributor. (don't know how that happens but yeah it happen!) his tach started going crazy after that. He replaced his cluster and everything worked perfect. Have you tried resetting the ecu?
Old Jun 20, 2007 | 04:34 AM
odogg726's Avatar
Default Re: possible VSS problem? (Dc2Point2)
nah, I haven't tried that yet, but the entire cluster works, except for the speed guage. I have another cluster laying around, I'll try it just to eliminate that possibility. Thnx. Anyone esle?
Old Jun 20, 2007 | 05:33 AM
veilsides2000's Avatar
I had the same problem. Try reseting the ecu, and if that doesn't help your situation then try switching the VSS for another one of your friends car or something. It fixed my problem
Old Jun 20, 2007 | 05:45 AM
forumnoobie's Avatar
Try unplugging the VSS and plugging it back in. Sounds simple but I had the same problem with the speedo not working and bouncing around. Just replugged it back in and works fine till this day.
Old Jun 20, 2007 | 08:58 PM
odogg726's Avatar
Default Re: possible VSS problem? (forumnoobie)
cool, will do. Thnx for all the input guys
Old Jun 23, 2007 | 09:39 PM
odogg726's Avatar
OK, so I've checked the fuse, I've tried another working speed sensor, and like everytime before, everthing else will work for about 2 miles except the speedometer, the speedometer just acts wacky. After about 2 miles or so, the speedometer, odometer, trip meter and vtec just all stop working or go away. Could it be possible that the cause of it is the speedometer on the cluster itself? I have a buddy who told me he had the same problem, bought a new cluster, and problem solved. I'm trying another cluster tomorrow, but what do you guys think?
blinger
11
Mar 26, 2024 08:08 PM
pancake
Sep 12, 2008 03:54 PM
JiVe
19
Jul 22, 2003 01:12 PM
TwoSaints
14
Jun 16, 2003 05:46 PM
