another abs delete question
Old Feb 21, 2008 | 05:30 AM
I Kick Squirrels's Avatar
Default another abs delete question
I am about to swap over all my stuff from my hatch to a 94 gsr shell....I read that everyone is using the rs mc and bb and a 40/40 pv.....I already have a 40/40 from a 93 integra..I was wondering if I could use a 92-95 civic brake booster and a 91 civic ex 15-16 master cylinder since it bolts up to the civic bb and uses civic lines....
so would I be ok swapping over my 40/40 and using the 91 15/16 ex mc and my 95 civic bb and lines to delete my abs from the 94 gsr.
let me know thanks.
Old Feb 21, 2008 | 05:59 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: another abs delete question (I Kick Squirrels)
Did you see the thread in the FAQ?
Old Feb 21, 2008 | 06:33 AM
jhammond_82's Avatar
Reject Papi
Default Re: another abs delete question (Dogginator)
probably not huh? abs removal thread. there you go.
Old Feb 21, 2008 | 08:53 AM
guess you guys didnt read my post so well....i know everyone is using the stuff from the rs integras.......i know on civic people use the 91ex master cylinder as an upgrade from the stock 13/16 civic one.....and use the 40\40 pv from a 93 intaegra for the rear disc as a replcement of the stock 30/30 from the civic which came with drums and they both use stock civic lines....what im asking is ....are the rs 15/16 the same as the 91 ex 15/16 and is the 95 civic bb the same as the 98 rs bb....so i could use stock civic lines on a 94 integra
Old Feb 21, 2008 | 08:58 AM
Dogginator's Avatar
Daisy... Daisy...
I would check the part numbers first. See my signature for links.
Old Feb 21, 2008 | 09:46 AM
I just looked at all the part numbers for the civic and integra and some 00 si parts. A good bit of people are using the 99-00 si pv but that part number does not match up to any of the other 40/40 valve...so im thinking it could still work.
the numbers pretty much didnt get me anywhere..if no one can answer this for me in the next few days im going to just go ahead and try it and I will let everyone know how it goes...hope someone has beat me to it and has already tried..
just waiting for an answer
thanks
Old Feb 21, 2008 | 10:15 AM
Dogginator's Avatar
Daisy... Daisy...
If you do get an answer, it should also be placed in the ABS delete thread.
Old Feb 21, 2008 | 01:34 PM
bump
Old Feb 22, 2008 | 11:08 AM
i take it no one has tried this before??
tortora
Mar 6, 2011 02:04 PM
X93siX
Jul 6, 2009 07:14 PM
oroca
Mar 20, 2009 07:25 PM
93civicsedan
Mar 3, 2004 06:55 PM
