Clutch Problem...Please Help!
Old Feb 23, 2008 | 01:05 PM
ricerEJ8's Avatar
Default Clutch Problem...Please Help!
ok so my clutch has recently started to loose pressure and now you have to press it all the way for it to work. It wont let me change gears or anything. The fluid reservoir next to the master cylinder(dont know what its called) is empty. Also the clutch fork is really greasy. I checked the master cylinder and slave for leakes and could not find any. Can anyone please help guide me through this?
By the way the car is a 95 integra ls
thanks
Modified by ricerEJ8 at 7:53 PM 2/23/2008
Old Feb 23, 2008 | 01:54 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Clutch Problem...Please Help! (ricerEJ8)
Look at the pad beneath the pedals for the lost fluid. You will most likely need a new clutch master cylinder.
You can temporarily fix this by adding more fluid to the reservoir and bleeding the slave cylinder.
Old Feb 23, 2008 | 03:55 PM
Ketone's Avatar
Default Re: Clutch Problem...Please Help! (Dogginator)
Sounds like you need a new clutch master cylinder or slave cylinder. They are both relatively inexpensive, I would just go ahead and replace both. As Dogginator said, a quick fix is to fill the reservoir up with more fluid.
Old Feb 23, 2008 | 04:04 PM
SlowPokeDB's Avatar
this just happened to me last week
my clutch pedal stuck to the foor and by leaving it there instead of picking it up i would just tap the clutch and my car went in to gear fine but yea youe clutch master cylinder and slave cylinder prolly have leaks
lil vin
Jun 21, 2014 01:30 PM
dgerej2
Oct 1, 2009 07:16 AM
707EF8
Jul 29, 2006 08:09 PM
RaceMyGhost
Dec 26, 2005 09:51 PM
DriveSideWays
Jul 4, 2004 05:07 AM
