Weird vtec problem. Please look...
Old Feb 19, 2008 | 06:44 PM
91EF_Si's Avatar
Default Weird vtec problem. Please look...
So I bought a 91 Civic with a 94 GSR swap. Vtec will only work if directly connected to a toggle switch and will bog in and out of vtec at around 6k +. Always done this since I've had it. Any ideas?
Things changed/checked.
Oil is fine.
Rewired vtec and other sensors.
Changed vtec selonoid.
Tried other virgin/chipped ecu's.
Running str8 pipe, so no cat.
And only CEL on throwing is 6 Engine coolant temp sensor, and thats because it's not plugged in.
Things that I think can cause the problem.
Preety bad dented oil pan.
Don't know the condition of either oil pump or oil pick up.
And maybe fuel, even tough fuel gauge reading 50 at idle.
Please help..
Old Feb 19, 2008 | 06:51 PM
beatthisspeed69's Avatar
Default Re: Weird vtec problem. Please look... (91EF_Si)
its because of that sensor u have unplugged cuz vtec will only work if car is at running temp...and ecu can tell if the motor is at running temp if thats not plugged in....and make sure ur speedo works cuz that can cause it not to work either
Old Feb 19, 2008 | 07:21 PM
91EF_Si's Avatar
Default Re: Weird vtec problem. Please look... (beatthisspeed69)
Speedo is always working. So it could be just that sensor and not bad oil pressure?
Old Feb 19, 2008 | 07:23 PM
yea i positive its that sensor cuz the same thing was happening to mine then my homie told me cuz that sesnor...just plug it in reset ecu and it should work withou a switch if u have the right ecu
Old Feb 19, 2008 | 07:29 PM
91EF_Si's Avatar
Default Re: (beatthisspeed69)
but why would it bog in & out of vtec??
Old Feb 19, 2008 | 07:31 PM
idk wat ecu u runnin it could be cuz u had it hooked to a switch
Old Feb 19, 2008 | 07:58 PM
91EF_Si's Avatar
Chipped p28. And i've tried 2 other chipped p28's and a gsr ecu and still the same.
Old Feb 19, 2008 | 10:21 PM
i would just plug that sensor in reset ecu wire vtec to ecu instead of switch and see if it makes a difference
Old Feb 20, 2008 | 08:49 PM
91EF_Si's Avatar
Bump...wired up the sensors so no more CEL. But it still does it.
help..
Old Feb 20, 2008 | 08:50 PM
91EF_Si's Avatar
Default Re: (91EF_Si)
Also vtec works propely now, no more vtec button.
Old Feb 21, 2008 | 06:53 AM
1dumbscreenname's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">but why would it bog in & out of vtec??</TD></TR></TABLE>
because the ECU doesnt want you in VTEC because of your temp. you are overriding what the ECU is telling it to do.
Old Feb 21, 2008 | 08:25 PM
91EF_Si's Avatar
Default Re: (1dumbscreenname)
now when i get on it alot CEL 22 comes on and hits rev limiter at 6500. changed oil and tried 2 other vtec oil pressure switches...and still bogging out of vtec. going to change the oil pan and oil pick up and see what happens...
Old Feb 21, 2008 | 09:35 PM
have u tried switching vtec seloinoids just an idea
Old Feb 21, 2008 | 09:38 PM
91EF_Si's Avatar
yep.
Old Feb 21, 2008 | 09:43 PM
is the ground for the vtp sensor good cuz i read somwhere that if the ground isnt that good it will bogg in and out of vtec
Old Feb 22, 2008 | 07:52 AM
91EF_Si's Avatar
yea all grounds are good.
Old Feb 22, 2008 | 08:06 AM
goota's Avatar
have you checked your timing? valve clearances? injectors?
Old Feb 22, 2008 | 08:10 AM
91EF_Si's Avatar
Default Re: (goota)
Nah haven't checked the timimg or valve clearance. I noticed 1 cam gear is +1 and the other is -1. But I don't think that will make vtec turn on and off..or would it?
injectors are clean.
Old Feb 22, 2008 | 08:13 AM
all-mtr-teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">So I bought a 91 Civic with a 94 GSR swap. Vtec will only work if directly connected to a toggle switch and will bog in and out of vtec at around 6k +. Always done this since I've had it. Any ideas?
Oil is fine.
Please help.. </TD></TR></TABLE>
What do you mean by bogging in and out of vtec. Do you mean vtec is engaging and disengaging? You may have a bad ignition module or something else other than a vtec problem.
Old Feb 22, 2008 | 08:16 AM
91EF_Si's Avatar
Default Re: Weird vtec problem. Please look... (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">
What do you mean by bogging in and out of vtec. Do you mean vtec is engaging and disengaging? You may have a bad ignition module or something else other than a vtec problem.</TD></TR></TABLE>
Yes.
Old Feb 22, 2008 | 08:47 AM
How do you know vtec is engaging and disengaging? You can barely hear vtec on a GSR motor, most of the time all you can hear are the secondaries that engage at 5850 RPM.
Old Feb 22, 2008 | 09:06 AM
91EF_Si's Avatar
Becuase you can actually hear vtec kick then turn off and on...
Old Feb 22, 2008 | 09:08 AM
Are you refering to the sound at around 6K rpm? That's not vtec. Stock GSR vtec is at 4400 rpm.
Old Feb 22, 2008 | 09:16 AM
91EF_Si's Avatar
Im running a chipped ecu that kicks vtec at 5200 rpm. Once it kicks it will start to act up.
Old Feb 22, 2008 | 11:22 AM
What cams and other mods do you have?
