Bpi velocity stack custom intake
Old Feb 21, 2008 | 05:28 PM
401tuner's Avatar
Default Bpi velocity stack custom intake
looking to make a custom intake for my gsr using a Bpi velocity stack with a K&N filter. Now im looking for some 3" piping to make it but im not sure if anyone has any suggestions on where to pick some up. Im not sure what angles i need to make it work with my gsr intake manifold, so if anyone could chime in and help out that would be great. Expecially the people who have done this before.
Old Feb 21, 2008 | 05:31 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Bpi velocity stack custom intake (401tuner)
Get 3" diameter PVC sewer pipe. It is thin wall and light weight. You can find many PVC elbows and simply glue the assembly together.
Old Feb 21, 2008 | 05:33 PM
401tuner's Avatar
Default Re: Bpi velocity stack custom intake (Dogginator)
you sersouly suggest using PVC pipe? Just asking because ive never seen it done before, nor have i thought about using that. But that might actually work.
Old Feb 21, 2008 | 05:38 PM
Dogginator's Avatar
Daisy... Daisy...
I have had PVC pipe running from my RF fender to the stock airbox for about 4 years. It is the sewer pipe that I suggested. I was even able to flute the pipe entrance with a heat gun. PVC has a glass temperature of 87 deg C (189 deg F), above which the pipe will soften. I doubt you will see temperatures that high under your hood.
Old Feb 21, 2008 | 06:47 PM
clockwork675's Avatar
pvc works fine, i know 2 people that hve had pvc intakes and ne was a turbo supra due to lack of finding one with the right bends when he wanted to drive it after his swap!
Old Feb 21, 2008 | 08:06 PM
K2sInteg98's Avatar
Default Re: (clockwork675)
i had this same post a while back. Obviosuly type r intakes have 3" piping but the best and cheapest way is to go on ebay and search for integra integra and just go through them and see which one tells you has a 3" piping. Some sellers mention in the discription either written or in their picture.
fox three
Mar 4, 2006 10:37 AM
c0l7hy
Feb 22, 2006 09:18 PM
Fatty_1775
Jul 27, 2003 10:30 PM
Elite Hatch
Sep 22, 2002 10:21 PM
Trigun
Apr 15, 2002 12:16 PM
