Axle replacement question
Old Feb 20, 2008 | 06:09 AM
funtak's Avatar
Default Axle replacement question
Well, two questions.
1: Do I have to drain and replace the transmission fluid when I change the passenger side axle?
2. Whats the best way to replace a balljoint? Dead blow hammer or should I buy a press?
edit; Might as well give it a mention that its a 94LS
Modified by funtak at 7:41 AM 2/20/2008
Old Feb 20, 2008 | 06:14 AM
climb_on's Avatar
Default Re: Axle replacement question (funtak)
as soon as you pull the axle stick a clean rag in the hole, it'll save most of your tranny oil. just double check your level when you finish.
are you trying to remove the ball joint so you can take the axle out? or you just replacing it cause its damaged?
Old Feb 20, 2008 | 06:21 AM
funtak's Avatar
Im going to replace the ball joint when I have the axle out, I think the one thats in there is messed up.
Old Feb 20, 2008 | 06:22 AM
95dc2teg's Avatar
Default Re: Axle replacement question (climb_on)
when i replaced my passenger side axle, absolutely no fluid came out....
Old Feb 21, 2008 | 11:31 AM
dwolsten's Avatar
You might be able to avoid losing transmission fluid if you jack up the front passenger corner.
To change the ball joint, rent a ball joint press from your local auto parts store. It's basically a big C-clamp with different size cups to fit different ball joint sizes.
clampjaw25
May 21, 2007 01:56 PM
JMod
Nov 19, 2005 07:47 PM
S.Celia
Jan 26, 2004 07:24 AM
See Are X
Oct 21, 2003 09:23 PM
