valve adjustment problem????
Old Feb 23, 2008 | 10:29 PM
F Bomb's Avatar
Default valve adjustment problem????
ok adjusted my valves to spec, (97' b18c1) .006 on intake, .007 on exhaust was a little tight and missing a little so i put them at .007 and .008... Anyways problem lies in the idle... when i start it the idle is so rough! Could it be that they are still to tight? Any help is appreciated.
Old Feb 26, 2008 | 09:06 PM
F Bomb's Avatar
anybody got suggestions??? its just when its cold, once warm idles smooth.
Old Feb 26, 2008 | 09:44 PM
all-mtr-teg's Avatar
Default Re: (F Bomb)
Were the valves adjusted when the car was cold? Also, it depends on your technique, how much lag on the feeler gauge is a hard thing to teach and learn. Eveyone will perform a valve adjustment a little differently because everyones concept of slight grag on a feeler gauge is different.
Old Feb 26, 2008 | 11:10 PM
F Bomb's Avatar
yep was cold, i'm gonna try the trick of one size bigger won't fit technique, hopefully that will help out...
Old Feb 27, 2008 | 08:34 AM
jhammond_82's Avatar
Reject Papi
did you read the faq about valve adjustment? just in case you didn't here. tools temp how to another how to. hope this helps you along some.
Old Feb 27, 2008 | 10:30 AM
F Bomb's Avatar
yeah I read it...
DaYZeD.1
Apr 19, 2008 03:07 PM
phoenix_iii
Mar 28, 2007 10:27 AM
A.E Motoring
Mar 24, 2007 06:53 PM
wullie_vtec
Apr 18, 2006 07:04 PM
street dreams
Aug 31, 2004 03:06 PM
