squeaking and leak
Old Feb 23, 2008 | 10:47 PM
syd2k5's Avatar
Default squeaking and leak
hi guys ,
i recently got a used 96 acura integra. I have this problem of the car squeaking whenever it goes over some rough patches on the road. I got a complete vehicle inspection done at firestone they suggested that the axles be changed because they got bent or something.i got it changed and after shelling out 500 bucks i still get the same noise..
I have another problem the floor mat below the passenger seat gets soaking wet i am not sure what may be leaking.
please help me out. If any one of you are from houston suggest me a good mechanic where i can get this done.
thanks in advance.
Old Feb 24, 2008 | 02:28 AM
chantha's Avatar
Default Re: squeaking and leak (syd2k5)
as for my car, the squeaking is from the suspension, when im riding over bumps and stuff like that. is your car in lowering springs or coil-overs
Old Feb 24, 2008 | 06:13 AM
syd2k5's Avatar
i cannot make out what u r trying to say ....(lowering springs and coil-overs)
Old Feb 24, 2008 | 08:05 AM
meet_friend_hk2's Avatar
I am riding on the S2 Pro-S and have the same issue...
My car squeaks too whenever I roll over the pot holes, road bump..
But I think it's normal because my coilover is too stiff comparing to the stock springs/shock...
syd2k5: do you know that if you have any aftermarket suspension??
Old Feb 24, 2008 | 08:57 AM
syd2k5's Avatar
Default Re: (meet_friend_hk2)
no idea man thats y i posted it here...so wat do u suggest i do to get rid of the problem..
Old Feb 24, 2008 | 10:06 AM
omnirage's Avatar
Default Re: (syd2k5)
I had the squeaks...when I changed out my skunk2 pro-s coilovers (uncomfortable) with my new GC/Koni setup (comfy!) I swapped out the old dried up bushings that sit over the springs with the new rubbery GC ones. No more squeaks, and I haven't touched any other part of my suspension (bushings).
Old Feb 24, 2008 | 11:00 AM
BoSox46GSr's Avatar
Default Re: (omnirage)
I as well have the squeaks, kinda annoying, but that leak, i also had in my 92 teg, there's a plastic piece at the bottom of your windshield where the wipers would hit, and if that's missing, water will leak in through there and come out your vents onto the floor.
Old Feb 25, 2008 | 05:48 AM
syd2k5's Avatar
thnx a lot guys will try that out c if that makes a difference...
PoorBoy_96civic
10
Sep 26, 2010 08:37 AM
PARADOX_sf
Suspension & Brakes
12
Nov 28, 2007 06:17 AM
jiggatone
Suspension & Brakes
Nov 15, 2006 05:56 PM
GS-R Power
Jul 27, 2006 02:43 PM
Eluzion
Jun 8, 2003 12:20 PM
