help on build
Your car wont run right with a aftermarket manifold and no tune, you need the IAB's disabled.
I really hope you know what you are getting youself into, all motor is a endless money pit and unless you have a lot of money you aren't going to be making any power at all.
if you searched you would know. looks like someone beat me to the correct answer tho. I will suggest that you research before you do anything else.
your call will also not run right with just cams and no IM, but to install the IM you will need a tune.
ha ok just wanted to see what you gys thought, ive seen tons of people run gsrs with ctr cams fine even with an aftermarket IM, but just wanted to see what everyone thought ahaha
yes from what i can tell you see alot of people running these mods, what you fail to see is that they are not plug and play.
Do you know why your gsr IM looks the way it does? Do you know how it works and how your GSR makes power? Do you know why the ctr cams need an aftermarket IM? some questions you should ask yourself before you move on.
turboedc2
20
Mar 8, 2006 08:18 AM
DeDonDeRosa
Oct 22, 2002 09:31 AM
