b18c1 starting problems
Old Nov 1, 2008 | 03:04 PM
everlight44's Avatar
Default b18c1 starting problems
Hello,
I have a 1995 Integra GSR that I've been having a fair number of starting problems with. The car will crank but not start, as in the starter motor will go but the motor will not actually start. This was only sometimes (oddly enough) and I replaced the distributor yesterday due to a bad bearing and now the car won't start at all with either the new (possibly DOA) or old distributor (that was working fine). I also replaced the main relay with one I know to be working awhile back, so I think that it is okay.
I'm exchanging the new distributor for a new one since it was DOA, but honestly I'm wondering if there's some other problem. Maybe a ground is screwed up somewhere? I honestly don't know... any ideas?
Thanks,
Sean
Old Nov 2, 2008 | 09:17 PM
Default Re: b18c1 starting problems (everlight44)
Could it possibly be spark plugs?
Old Nov 3, 2008 | 02:12 PM
mouab18c1's Avatar
when you took off ur distributor and slapped on the new one. did you put your wires back in the right order? and you can also check if your spark plugs are worned out
seearevee
Honda CR-V & Element
Dec 13, 2016 05:25 AM
ef yu
Mar 20, 2012 11:58 PM
everlight44
Mar 12, 2009 07:57 PM
taterbug
Dec 29, 2008 10:23 AM
SpeedMonkeyRacing
21
Oct 29, 2002 12:51 PM
