code 3, map, and now guage cluster doesnt work????
Old Nov 3, 2008 | 11:35 AM
msinsky14's Avatar
Default code 3, map, and now guage cluster doesnt work????
i finally got my ecu code 6 off, but now i have a code 3, map sensor, and the entire guage cluster went off.
wats goin on!!!!
Old Nov 3, 2008 | 12:19 PM
msinsky14's Avatar
Default Re: code 3, map, and now guage cluster doesnt work???? (msinsky14)
bumpity bump. clock doesnt work either
the only light that turns on in the guage cluster is the battery light. this is really weird
Old Nov 3, 2008 | 01:04 PM
msinsky14's Avatar
guage cluster was just a fuse.
but how do i fix code 3? its just a wiring problem for the map sensor?
Old Nov 3, 2008 | 04:43 PM
msinsky14's Avatar
bump for code 3!!!
Old Dec 28, 2008 | 06:46 PM
supermonkey's Avatar
bump same thing happened to me.. throwing code 3 for map sensor and for some weird reason I blew my cluster fuse..
Here's the story. I'm running on an ls computer right now. I have an eg with a gsr. So I was throwing code 41 for o2 sensor from the beginning. The wire harness I had in the car was all hacked. So I changed it with another gsr harness. And now I'm throwing code 3 map sensor out of no where. So I'm like wtf. I changed the sensor, still throwing map sensor code. So I put the the harness that was originally on it. Still same problem.
I put the new harness back on triple checked the ground the therm. housing. And I also somehow blew the cluster fuse in the process.
relentlesstech
Apr 10, 2014 06:22 PM
d_boi_swag
Jul 5, 2009 12:14 PM
D C 5
Jun 19, 2005 11:01 AM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
