+5V Wire?
Old Nov 4, 2008 | 05:21 AM
The G2 Racer's Avatar
Default +5V Wire?
Need to tap into a +5V wire at the ECU, car is ODB1.
What wire will supply this?
Old Nov 4, 2008 | 01:59 PM
Perfectionist's Avatar
Default Re: +5V Wire? (The G2 Racer)
The ECU isn't a power supply. Pretty much any wire that has 5 volts on it is feeding a sensor. Tapping that line will muck up what the ECU sees off that sensor and could cause driveability problems.
What is it you are trying to achieve?
Old Nov 4, 2008 | 03:09 PM
majinsoftware's Avatar
you can use the 5V from the datalogging port, Thats the only one I can think of.
But it will be best to make a 12 to 5V inverter or just pull apart a cig ligher phone charger.
Old Nov 4, 2008 | 07:01 PM
Default Re: (majinsoftware)
I'm hooking up a Modifry ECT converter to run the coolant gauge in my S2000 cluster.
IT NEEDS +5V, 12 will fry it.
Old Nov 5, 2008 | 09:35 AM
twentyhurtz's Avatar
Default Re: (The G2 Racer)
yea you need a dc to dc power adapter, when dealing with computers (5v) as stated above its for signal or sensors, granted its 5v but the usually after 500ma-2a on some you will initiate some "ummm toastyness!" just make sure when you get your converter you check the max amp rating on it to ensure you have a safe setup.
Old Nov 5, 2008 | 05:08 PM
xalents23's Avatar
I tapped my CRX ECU at location C13 which is a yellow/white wire. To get power to the modifry unit. This is the wire which sends a +5V to the modifry unit. Remember not to connect any other power wire higher than a +5v to the Modifry unit. If you do it will damage/fry the Modifry unit. This is for a Honda CRX and the +5V will be different on other cars.
jtracing919
Jan 11, 2005 06:45 AM
dingusjt
Nov 13, 2003 10:18 AM
crucial si
May 27, 2003 06:35 PM
Jago
May 25, 2003 11:21 AM
RAWB
Feb 6, 2002 10:27 PM
