Suggestions?
Old Nov 3, 2008 | 10:33 PM
SeDA(9)n's Avatar
Default Suggestions?
What is the recommended weight for a flywheel on a turbo car running 10psi?
Old Nov 3, 2008 | 10:54 PM
majinsoftware's Avatar
Depends how well you want it to drive, Stay with stock when in doubt.
Old Nov 3, 2008 | 11:32 PM
SoTexDC2's Avatar
Without knowing the specifics of your setup, 10 PSI means nothing.
Larger turbo = Higher CFM = higher power on the same boost level as a smaller turbo.
As for the flywheel, don't base your decision on the fact that your motor is boosted. A lighter flywheel lets your engine rev up slightly faster, but also causes it to rev down much quicker than normal. Stock is perfect for a daily driver, but a light flywheel can also be tolerable in a DD after you get used to it.
95dc2teg
Sep 17, 2006 05:21 PM
IntegraMastaz
Dec 27, 2005 02:40 PM
VtecInteg95
Dec 11, 2003 03:04 PM
Fuzion
20
Sep 19, 2003 03:24 AM
austrian type-R
Sep 21, 2002 08:38 PM
