help with integra
Old Nov 2, 2008 | 05:08 PM
93integrals's Avatar
Default help with integra
hello. i recently ( 2 weeks ago ) bought a 1993 integra LS and it just rolled over 160k a few days ago. Me and my friend were driving it around and i noticed earlier that it like to sputter around 3000 rpm and up and would almost like to die out. ( not a good thing on the freeway lol) so i took it to my frends house and we decided that we were going to take a look at the spark plug wires and the plugs. Well when i took off the ( when your looking at the car, the second cylinder to the rightof the passenger) which is #2 i believe. Anyways i took the wire off and i couldnt even see the plug there was so much oil in the well. Plus when i pulled out the wire the little boot thing at the end broke off so its junk. So i was inspecting the other wires and they all have cracks in the plastic and i didnt think that was good. so i bought new wires and plugs and installed them and now it runs really good. But i do want to know what caused all that oil to get into the plug well. Either a bad valve cover gasket or something u think. Another question, how many seals does the engine have around the plug wells? Is it just the valve cover gasket and the head gasket or are there more. And also if i do have to replace the valve cover gasket, will that solve the oil in the plug well problem? Thanks Andrew Olson
Old Nov 2, 2008 | 05:15 PM
slaminsam's Avatar
Default Re: help with integra (93integrals)
With oil in the spark plug tubes it really sounds like that one of the o-rings on the valve cover leaking. When you purchase a new valve cover set it should come with the four o-rings.
Old Nov 2, 2008 | 06:02 PM
Default Re: help with integra (slaminsam)
hey thanks, i will look into getting a new valve cover gasket set. How much do u think that will cost? thanks again, Andy
Old Nov 2, 2008 | 06:49 PM
slaminsam's Avatar
OEM
http://www.acuraoemparts.com/d...ch=no
Felpro
http://www.partsamerica.com/Pr...Set=A
Old Nov 3, 2008 | 01:39 PM
hollums2k's Avatar
better do a compression test to make sure your piston rings arent putting that oil up in there...id do leakdown too while your at it and check valve seals...
preludepower01
Feb 18, 2011 03:59 PM
yhonda
Jul 17, 2008 08:47 PM
Sic_DA_Nine
Feb 13, 2007 07:39 PM
74celicagt
Feb 25, 2006 07:03 PM
Shizznaz
Feb 25, 2005 09:12 PM
