function and form installation?
Old Nov 3, 2008 | 12:12 PM
djteggy99's Avatar
Default function and form installation?
im having a little trouble with my function and form coilovers. are you suppose to be able to move the two rings with the adjustable tool cause i cant move mines at all and it is shorter then my tokico blues?Help?
Old Nov 3, 2008 | 12:16 PM
SuzukaBlueAP2's Avatar
Default Re: function and form installation? (djteggy99)
You should have been supplied with one or two spanner wrenches to loosen the perch. That is what allows ride height adjustment.
Old Nov 3, 2008 | 12:31 PM
djteggy99's Avatar
Default Re: function and form installation? (SuzukaBlueAP2)
yeah the thing is that the strut is short when i stick it in the fork it doesnt reach the top to were i screw the two bolts on top.Could it be they give me the wrong ones?I have a dc2 99 gsr
Old Nov 3, 2008 | 12:36 PM
Benard's Avatar
you have to jack up the lower control arm to raise it into place
Old Nov 3, 2008 | 12:37 PM
djteggy99's Avatar
Default Re: function and form installation? (Benard)
so just jack up the lower arm is that gonna be okay?
Old Nov 3, 2008 | 04:06 PM
djteggy99's Avatar
okay i got the coilovers in but the two rings i couldnt get it to spin at all haha its hella hard.Whats a good way to loose them i tried hard.
Old Nov 7, 2008 | 02:25 PM
djteggy99's Avatar
anyone can help me out.i cant turn the rings at all i twist it like maybe just alittle but its freaking hard i used the tool for it too.
Old Nov 7, 2008 | 02:44 PM
mayoforlife2's Avatar
are they new or used
Old Nov 7, 2008 | 02:46 PM
SleeperGSR's Avatar
It is hard to turn them. If you are trying to lower your car you will need to compress the spring, you willl have to put some muscle into it. At least that's what i did, maybe someone has a trick but i think you just have to try harder.
Old Nov 7, 2008 | 03:14 PM
djteggy99's Avatar
Default Re: function and form installation? (SleeperGSR)
well my bro told me that were not suppose to adjust the two rings but the legs or something like that where the ring on the bottom locks the legs after i lower it or higher it.
Old Nov 8, 2008 | 01:00 PM
correct
NyPosterBoy
Suspension & Brakes
22
Mar 11, 2010 06:31 PM
egtony
Jun 29, 2009 12:02 AM
danvuquoc
Suspension & Brakes
Jul 16, 2006 08:12 AM
white4doorsi
Feb 15, 2005 07:19 PM
Red_Si
Jun 25, 2003 09:41 AM
