installing cams
Old Oct 31, 2008 | 01:59 PM
sir_mugenpower's Avatar
Default installing cams
what would i have to do in order to install skunk 2 cams and what size feeler gauge would i have to use??? i'm just looking for a step by step scenerio that shows or explains exacly what i would have to do please help me out with this one!!!1
Old Oct 31, 2008 | 02:59 PM
stickyicky's Avatar
I think you can use this...
https://honda-tech.com/zerosearch
Old Oct 31, 2008 | 03:15 PM
majinsoftware's Avatar
Default Re: installing cams (sir_mugenpower)
First what engine do you have?
Get the helms manual to tell you what adjustment you need for the valves.
Then get some assembly lube.
Now its just a matter of undoing bolts and removing the old ones then sticking the new ones in with the motor at TDC and everything lining up.
If your engine has done a few ks then you might not even need to adjust the valve lash because it will be lose already, as mine was but with in spec for my engine.
Old Oct 31, 2008 | 08:30 PM
ACTION JACTION's Avatar
Depends on what model cams you are running.
I believe most skunk2 B series cams are .007 intake and .008 exhaust
Old Oct 31, 2008 | 09:21 PM
racebum's Avatar
Default Re: (ACTION JACTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACTION JACTION &raquo;</TD></TR><TR><TD CLASS="quote">Depends on what model cams you are running.
I believe most skunk2 B series cams are .007 intake and .008 exhaust</TD></TR></TABLE>
x2 your cam card will have clearance specs. if you buy used skunk will either give them to you or they may have them posted. most performance cams run .006 or .007 intake and .008 exhaust.
Old Nov 1, 2008 | 08:33 AM
thanks guys i appreciate it well to answer what someone asked i have the B17 gsr in the DA....idk if that helps with what i should gap the lobes at!!!
lifeschase
Honda CR-V & Element
May 28, 2016 09:03 AM
EFjoe91
54
Mar 10, 2011 08:17 AM
raiden571
Jul 29, 2009 07:39 AM
letholone
11
Jul 2, 2003 08:52 PM
InfamousRS
May 12, 2002 03:02 PM
