5 lug conversion question
Old Oct 31, 2008 | 11:47 AM
The_Ricky_Is's Avatar
Default 5 lug conversion question
alright, quick question.
i tried searching and couldnt come up with a answer for my question
alright, if i do a 5 lug conversion, will i be able to keep my old suspension?
Old Oct 31, 2008 | 12:05 PM
HONDRETTI's Avatar
Default Re: 5 lug conversion question (The_Ricky_Is)
depends. if you go jdm itr hubs, you need to upgrade your axles to that spec (i think its 36mm) if you go usdm itr hubs, you can keep your LS or whatever axles bc they are the same (32mm).
Old Oct 31, 2008 | 12:16 PM
Default Re: 5 lug conversion question (HONDRETTI)
i have a gsr , would teh axles fit with that?
so, the jdm hubs wont be able to use my full coil overs?
Old Oct 31, 2008 | 01:10 PM
hatchling37's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Ricky_Is &raquo;</TD></TR><TR><TD CLASS="quote">so, the jdm hubs wont be able to use my full coil overs?</TD></TR></TABLE>
I'm very positive you will be able to bolt them up. At most, you're swapping over whole knuckle assemblies and forks, and they should bolt right up to your LCA. Someone please correct me if I'm wrong...
Old Oct 31, 2008 | 01:50 PM
BlueIntegraBoy's Avatar
I see a lot of beating around the bush answers here.
YES, you can keep your own suspension with the 5-lug conversion. You don't need to swap the rear LCA to an ITR one. As long as you use your stock LCA in the back, you'll be good.
Old Nov 12, 2008 | 06:49 PM
insidiousDC2's Avatar
Default Re: 5 lug conversion question (BlueIntegraBoy)
yes you can keep your suspension.I put a jdm 5 lug on my Teggy 2 weeks ago,the only difference was the axles(36mm) USDM 5 lugs use regular integra axles(32mm)
cashkid2004
Oct 1, 2006 06:41 AM
RhdDc2R
Suspension & Brakes
Feb 16, 2006 06:36 PM
SPOONfdEK
15
Apr 1, 2005 03:39 AM
253EK
May 20, 2004 08:08 PM
TheHater
Dec 20, 2002 07:58 AM
