automatic seatbelt removal? da teggie
okay so my drivers automatic seat belt wont go back to the start position its stuck like in the lock position so i have to disconnect the seat belt every time and its become a hassle. so i was thinking about getting like a 4pt harness, but how would i make the seat belt light go away if i removed the original seat belts?
Re: automatic seatbelt removal? da teggie
Remove the passenger side plastic area lower cover, itll be directly to the right of your feet if your setting in the passenger seat. Behind that cover, is the seatbelt control unit. You unplug the 2 plugs going to that and bam, no more seatbelt notification beeps or lights or anything.
thanks man, what do you guys think if i get the regular 4 point like seat belt style not like the ones where you got the circle and put in each strap
