ABS Delete
So I took off the ABS system of my DA today cause the lines were all different sizes what I want to know is will there be a difference in the braking or no? and what are pros and cons of this?
I'd like to know how well the braking is or any issues that could arise from converting my LS brake system (from its original but failing ABS) to an RS model non ABS system as well.
Who here has done this, and were there any issues afterwards since were already on this topic?
I already finished doing this today took off the abs system cause it was giving me problems. My brake pedal will sink to the floor with no resistance and it came to the point where if I wasn't using my ebrake my teg wouldn't brake. Took it off and problem solved.
If Im mearly changing my factory ABS equipt LS to a non abs system like that of the RS DC4 then why would there be any issues there? Do RS's have the tendancy to lock often?
Personally I think it would be just fine, but I wanted to hear from people who have done it and see what they said about any issues that they had, if any at all.
breaking w.o abs SUCKS
i had an integra that didnt have abs,
and in rain and snow its way harder to brake cuz u need to pump
and thats a hard habbit to break
if u dont need to remove it DONT
trrust me
blows
trrust me
blows
except during hurricane season. lol. its one of those however you like it kind of deals. i like abs, but i live where we get snow in the winter time, so it can be a life saver. thats just me though.
That's the same problem I had. The resevoir was leaking and there was also leaks on some of the lines. I didn't find a write up on it. My dads friend has done it before and he came by and helped us we just went to a junkyard picked up a couple of lines and a couple of other parts the friend needed. Now I need to replace the booster cause that got messed up too. I'll finish it maybe tomorrow or the weekend and drive it around and see what the main difference is.
From: Staring down the barrell of my 12 ga. Texas, USA
i think the only thing to worry about is the prop valve, i dont remember where i read this, but i want to say the abs and the non abs have different ratios. i know the da non abs is a 40 40, and i want to say the abs is a 50 40 or a 60 40... im not positive, but ill look again. ive looked into this, my abs is locked up, so its just extra weight on me, and i have the motor out now anyways
Well I finished taking off the ABS. Got a new Booster and a Master Cylinder. I think it's better to have the ABS but I couldn't find a used one at a Pick a Part so screw it but the braking is decent it could be better I still need to replace my rear pads so maybe that would make a difference who knows.
Agreed 100% if you plan on doing any type of high performance driving you better off with it. I know i'm going to get flamed for saying this, but ABS has kept my car on the track. I get to about 4 HPDE per year, and ABS will save your car. A show car with a shaved bay, by all means get rid of it. But if you are going to be doing anything from an auto cross or a HPDE even to being johnny ricer on public roads, you're better of with it. I know you made up your mind but for anyone else who reads this, not a good idea. BTW it was sunny and dry when ABS kept my car from hitting a wall on the track. And if you are good brake modulation your ABS will not go off unless its needed.
For me, I wasnt considering doing it for any kind of cosmetic/appearance reason. I've had issues with my ABS and have tried everything in the manual to correct it but I suspect that its probably failing due to the age of the car so I wanted a cheaper solution then replacing the ABS unit.
I'm going to try a few more things/spend a little more money into other apsects of my brake system to see if that fixes the problem but if it doesnt then I might end up doing this unless I find a working ABS unit off a used model for a decent price, IDK.....
SpeedFreek34
Jul 22, 2007 05:43 PM
