Door panel inserts for two door DC , need help!!
So i give it a shot today , and it doesn't turn out too bad, but not to good either. How do you get the edges of the fabric to "tuck" around the lip like it did from the factory, it seems as if the fabric would have to be cut within 1/16" of an inch to look nice, I tried using the stock fabric as a template....and well.... it wasn't that great. I also read the write up on TI but it does not go into detail on tucking the edges. And when spraying the fabric, do you just spray the center and tuck the edges? Because now I have adhesive on my door panel, which I assume adhesive remover will so just fine removing.
thanks in advance!
thanks in advance!
crxaddikt
Dec 10, 2014 07:01 PM
