Jun cams
Someone offered me some jun 3 cams. can someone give me some specs would be going into b18c. I see there an agressive cam,or are they to much for stock motor
They are a aggressive cam and you would have to do additional work to use them. You'd need to upgrade your valve springs for sure, and retainers while you're at it would be a great idea. Also a tune would be very neccesary afterwards. Then you'd want to do other things to make more power, like higher compression pistons.
If I were you and just wanting to add the cams, i'd pull the head, hottank and resurface the head, new valve stems, some good valve springs and retainers, the cams and a good intake manifold/throttle body. Then a tune immediatly afterwards. As far as just throwing the cams in and going, far from a good idea.
I was just offered them they hadnt sent me a price and I started looking them up and there $600 and up and theres no way im spending that when I can get something decent for half that price
if you got aggressive cams like that youll have to buy more internals just to make it compatable with your engine, if you want a good semi cheaper power increase. just get some itr/ctr pistons and some bolt ons
Are cam gears necessary. I have seen most people have them and they can tune to a different degree but I talked to a guy that owned a shop and he said there just for show and you can get the same from your stock cam gears..
And also im looking at getting the blox racing type a camshafts, it says the valvetrain doesnt need to be changed is this true? I know I shouldnt go cheap on it but is it really necessary
the jun 3 is probably the best vtec cam made. the endyn bumpstix is heavily based on that design
thehatchninja
Jun 10, 2005 11:37 AM
