DC2 Brake light problem.
They aren't coming on. all the running lights work fine as well as turn signals.
I checked the fuses, but still no luck.
It all happened around the time i took my wing off, but i tried reconnecting the lines and that didn't work either.
This might be the issue but check the brake petal. Theres a little rubber grommet the size of a chocolate chip that fits in a small hole on the petal shaft that makes contact with a switch. Either replace/reinstall or just put a small nut+bolt there which wont make its way, thats what I did.
asocallocal
Aug 29, 2010 07:00 PM
Captain JDM
Oct 23, 2006 11:35 AM
