problems with swap
Old May 18, 2009 | 05:55 PM
canospeed200's Avatar
Icon3 problems with swap
well i did a swap on my gsr integra and i put a jdm type r engine. i used the jdm wiring hardness went right in no problem but the jdm ecu a p73 didnt work on it so i use the gsr one. then the problem started! the car started but i try to drive it and it started bogging and a couple back fires also i couldnt go past 5000 rpm. can anybody please help!!!!!!!!!!!
Old May 18, 2009 | 06:00 PM
mouab18c1's Avatar
Default Re: problems with swap
your ecu is your main problem. running a gsr ecu on a type r motor. what year is your car? and year of the jdm itr motor?
Old May 18, 2009 | 06:12 PM
wunfstgsr's Avatar
Loved
Community Favorite
x2
Old May 20, 2009 | 04:42 PM
the car is 2000 gsr and the engine is 96 type r but i thought that i would still be able to at least use the gsr engine and getting running
Old May 21, 2009 | 06:45 AM
mouab18c1's Avatar
your starving your motor
Old May 21, 2009 | 09:41 AM
DC206R's Avatar
x3. find a 96 or 97 ITR ecu.
or maybe a P28
Old May 21, 2009 | 05:34 PM
am going to look into that then i found one for $175 and is a 96 type r one
Old May 22, 2009 | 07:06 AM
mouab18c1's Avatar
i say get a p28 and just get it chipped..
Old May 22, 2009 | 10:37 AM
punxsk8r555's Avatar
for your type r swap did you have to run any wires for the vtec or anything im about to do one right now, or did you jusrt plug in the harness to the gsr harness and plug the ecu in. i have the right ecu for the 97 type r andthe engine harness but the whole dash harness is a ls.
slimsdizz
Aug 15, 2010 08:24 PM
GsRated
Sep 26, 2006 05:14 AM
Superdragr45
May 28, 2004 09:58 PM
sohc it to me
Sep 16, 2003 10:28 AM
sohc it to me
Sep 16, 2003 10:14 AM
