engine harness help
Old May 15, 2009 | 10:36 AM
dragon007's Avatar
Default engine harness help
GSR obd2A engine harness is the same as GSR obd2B engine harness????
Old May 15, 2009 | 11:05 AM
dragon007's Avatar
Default Re: engine harness help
To the top
Old May 15, 2009 | 03:36 PM
dragon007's Avatar
Ttt
Old May 15, 2009 | 10:01 PM
PaulMc's Avatar
Painfully Stupid
The VTEC wiring may be a little different, not positive, if you can explain a little on why you're asking maybe someone else or I will be able to help
Old May 16, 2009 | 10:49 AM
dragon007's Avatar
Thanks for the reply.
just asking a straight question.
obd2A ecu and obd2B ecu is different,
I was wondering the engine harness is different or the same
Old May 17, 2009 | 12:46 AM
dragon007's Avatar
ttt
Old May 17, 2009 | 04:16 AM
94EG8's Avatar
Seagull Management
Very slightly different. The OBD2A harness has a tach signal wire coming from the distributor plug that the OBD2B harness lacks (meaning that if you use an OBD2B harness in an OBD2A car you wont have a tach) thats the only difference I can think of.
Old May 17, 2009 | 09:12 AM
dragon007's Avatar
wow, useful info.
anyone with different info
Thanks
Old May 18, 2009 | 09:30 PM
dragon007's Avatar
ttt
zdiddy22
Oct 14, 2013 08:51 AM
ltrkstr2k
Sep 28, 2010 03:36 PM
chrisfromsrq
Feb 7, 2010 06:03 PM
ca-rs
Jul 16, 2008 03:33 PM
josh green
Jan 20, 2005 04:19 AM
