UCA's Question
Old May 30, 2009 | 09:50 PM
TonyRomo's Avatar
Default UCA's Question
I just got new upper control arms cause one of them broke.
The new ones are skunk2's and the alignment is still perfect, but do I need to get an alignment so that they can adjust the camber on them?
The car is dropped 1.5" I believe.
Old May 31, 2009 | 02:18 PM
BMXman's Avatar
Default Re: UCA's Question
It's always a good idea to get an alignment done after replacing suspensions parts such as control arms....I don't understand how you say the alignment is perfect but then ask should you get an alignment done???
Old May 31, 2009 | 04:50 PM
blac00si's Avatar
+1
Just because it looks good, doesn't mean ****. All of your toe and camber is done in degrees. Your not going to be able to look at it and see if its good.
Go to firestone.com they have printable coupons for $15 off a standard alignment. I get mine done there, takes about 1 hour and you get a printout showing exactly what everything is set at.
Marvin1985
19
Mar 17, 2015 08:58 PM
g0tgot
Suspension & Brakes
14
Feb 23, 2009 04:00 PM
KRock459
Feb 15, 2009 04:48 AM
tmrtwo
Aug 12, 2007 12:04 PM
DeLiRiOu5
Oct 7, 2003 05:04 AM
