Idleling problem
Old May 26, 2009 | 06:28 PM
FinedTuned's Avatar
Default Idleling problem
Hi guy I just bought a 94 teg ls. The previous owner rebuilt the ls engine back to stock, it runs good and everything but the idleling flunctuates between 500-1500 rpm. Sorry I dont have the helms yet I bought the car yesterday. How do I go about fixing this? Thanx guys
Old May 26, 2009 | 08:54 PM
stevenDAtegra's Avatar
Default Re: Idleling problem
You either have a vacuum leak somewhere or the IACV is dirty
Old May 26, 2009 | 08:55 PM
questo209's Avatar
Check the Idle valve located under the Throttle Body. Also make sure that your cooling system has been bled of any excess air. If after both of these items have been cleared and the problem still persists check the IAC on the back of the intake. After that if you still have the problem then there is a vaccum leak somewhere. Hope this helps.
Old May 27, 2009 | 07:06 AM
FinedTuned's Avatar
Yup this helps alot thanx for you help
Old May 27, 2009 | 07:50 AM
BaMBaM4002's Avatar
unplug the IACV (electrical connector) and see if the car turns off, if it does then you need a new IACV otherwise the car should just idle very low (perhaps under 200rpm) Now if it does do that then check the cleanliness of the filter in the IACV, if that is clean then i suggest checking the FITV under the IACV (Clean the FITV) If the problem persists then go check all the vacuum lines and feel for leaks etc.
If all that fails then you can always try to reset the idle by adjustiung the idle screw on the Throttle Body.
Old Jun 15, 2009 | 09:20 PM
Raizen408's Avatar
When you do clean the IACV I recommend using compressed air with some good old carb cleaner does the job really well. Don't forget to take off the rubber rings before spraying inside the two holes because it will swell up.
Old Jun 15, 2009 | 11:31 PM
kroze's Avatar
any update on what the problem was?
Old Jul 30, 2009 | 05:49 PM
Tunerguy1989's Avatar
How to you go about bleeding your coolant system? because I recently put in a new radiator and I think there is lots of air in the system.
Old Jul 30, 2009 | 06:24 PM
teg1995's Avatar
New User
fix it?
Old Jul 30, 2009 | 06:25 PM
teg1995's Avatar
New User
it should be a vacuum leak most likely.
asianrepnsb
12
Mar 8, 2008 12:26 PM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
R. Mack
Jun 1, 2005 07:55 PM
eL
42
Sep 3, 2004 02:30 PM
wolf3007
Mar 26, 2004 05:06 AM
