Need help with wire placement!
Old May 30, 2009 | 05:06 PM
DC4jdmIntegra's Avatar
Icon2 Need help with wire placement!
i have a 94 ls and cant seem to find where this wire plugs into or onto... Do i need this wire either? if anyone knows where it goes and what its for, please let me know!
http://i97.photobucket.com/albums/l2...RRRRRRRRRR.jpg
Old May 30, 2009 | 05:12 PM
jdm_bones's Avatar
Default Re: Need help with wire placement!
Follow it...what does it go to...that's a really bad picture.
Old May 30, 2009 | 05:22 PM
aasarsak's Avatar
This is a joke right?
Old May 30, 2009 | 05:23 PM
jdm_bones's Avatar
You too right...hahaha! These cats now in days! WOW
Old May 30, 2009 | 05:29 PM
Icon3 Re: Need help with wire placement!
Here is the other end of the wire.
http://i97.photobucket.com/albums/l2...1/DSC00613.jpg
Old May 30, 2009 | 05:31 PM
aasarsak's Avatar
So which end are you asking about? The one that plugs into the positive terminal of your battery, or the one that goes to your starter?
Old May 30, 2009 | 05:34 PM
No its not the wire to the starter. that wire requires a 12mm nut, this wire looks like a
10mm bolt goes to it? originaly i had it bolted onto the thermostat housing but it doesnt seem right.
This is where i had it. going from positive battery terminal to here. LOOK
http://i97.photobucket.com/albums/l2...gine111111.jpg
Old May 30, 2009 | 05:35 PM
aasarsak's Avatar
That would be my guess. Have you looked at your starter? Do you see anything missing there?
Old May 30, 2009 | 05:48 PM
Old May 30, 2009 | 05:51 PM
aasarsak's Avatar
This must be a joke.
That is the engine ground. If you put it there, you will ground out your battery.
Look at your starter. How many wires are connected to it?
Old May 30, 2009 | 06:19 PM
One wire is bolted down to the starter and another is plugged into it. so this wire is just a regular ground wire?
Old May 30, 2009 | 06:22 PM
aasarsak's Avatar
no. You shouldn't have any positive wires from the battery to the engine block ground (thermostat).
Who unhooked that cable anyway? Where was it connected before?
Old May 30, 2009 | 06:41 PM
thats the thing, ive done swaps before but never have seen this wire before. i dont remember where that wire came from or goes.
Old May 30, 2009 | 06:47 PM
by the way its a white wire thats coming off the battery
aasarsak's Avatar
You've done swaps before, and you seriously connected a wire from the positive terminal of your battery to a ground? C'mon guy...
Anyway, give us some history here. . .
Where did that wire come from?
Is this a swap that you're trying to do?
If it's your car, and you haven't done a swap, then the wire must have come from sonewhere! Did the wire magically appear? What are you trying to do here?
Old May 30, 2009 | 06:48 PM
blac00si's Avatar
Wow, you are all a bunch of idiots.... I guess none of you have ABS in your integras.... That is a power wire that runs to the ABS fuse box located next to your ABS pump.
Everyone is ragging on the guy and none of you even know where the wire goes.
Old May 30, 2009 | 06:51 PM
aasarsak's Avatar
Lick my nuts. He had it connected to the engine block!
Besides, ABS is for pussies
Old May 30, 2009 | 06:58 PM
blac00si's Avatar
I just like to act like i'm 16 again and say stupid **** to people online makes me feel young again.
Old May 30, 2009 | 06:59 PM
blac00si, you are a genius. THANK YOU.
This is the first car ive done a swap in with ABS so screw you aasarsak. ive done alot of swaps before and know what to do with the exception of this one. so lick it.
Thanks again blac00si
Old May 30, 2009 | 07:04 PM
aasarsak's Avatar
dude, my 14 year old kid brother knows better than to ground a positive battery lead. That has nothing to do with knowledge of cars, it's just plain old common sense. LOL
I'm glad you found your fix though.
Welcome to HT
Old May 30, 2009 | 07:05 PM
blac00si's Avatar
Now im going to use my jedi mind tricks to let you know that you owe me a million dollars and you can paypal it to me.
aasarsak's Avatar
I know right? Makes your ***** feel like 15 lbs. each huh?
Old May 30, 2009 | 07:08 PM
blac00si's Avatar
Welcome to HT
everyone has to start learning somewhere... i have been working on honda/acuras for 12 years, had 7+ ef hatches with swaps, crx's, da's, eg's... been here since 2003 and on clubs si since 2000... I still learn new things all the time.
Good Luck with your car, hope that everything goes well with your first swap.
:thumbsup:
Old May 30, 2009 | 07:11 PM
aasarsak's Avatar
ROFLMFAO
Robert Williams
Apr 4, 2019 08:49 AM
Spicoli v 3.0
Audio / Security / Video
23
May 3, 2007 05:25 PM
AllmotorEH2
Welding / Fabrication
Feb 28, 2005 08:48 PM
Al Bundy
12
Mar 28, 2003 01:14 PM
