low intake temp
Old Jun 2, 2009 | 07:11 AM
JJtegfan14's Avatar
Default low intake temp
So i've been noticing that my 98 gsr doesnt heat up all the way. I changed out the thermastat so that's working fine. I'm even running a jrsc at 8psi but for whatever reason it's just not heating up all the way i'm at about 30% on the tempature guage.
What's the problem
Old Jun 2, 2009 | 11:02 AM
dothacker's Avatar
Default Re: low intake temp
30%... isn't that's where it's supposed to be at? 1/3 of the gauge... correct me if i'm wrong.
Old Jun 2, 2009 | 11:05 AM
SuzukaBlueAP2's Avatar
It will be damn near 1/2 with an OEM thermostat. When you replaced it, did you go with an OE?
Did you properly bleed the coolant system after you replaced the thermostat?
Old Jun 2, 2009 | 02:38 PM
JJtegfan14's Avatar
yeah i had it done professionally with the oem one. I think the fan is coming on to early and not letting it heat up properly
hondaelite.gov
Apr 3, 2015 08:45 PM
ax77
Apr 24, 2012 03:02 PM
Chuethou_b18c5
Mar 15, 2007 11:55 AM
S@nt0s
12
Feb 25, 2004 05:16 PM
