type r header on DA
Old May 23, 2009 | 06:09 PM
still4punk's Avatar
Default type r header on DA
i searched and cant find much on the topic. I got a type r header from my friend. Went to install it today and i could not get it between the block and cross member. Is there a trick or special way to make it work? I took out the radiator and fan and still not enough room to wiggle it in. Do i need to modify the cross member? Also the type r header is slightly shorter than my stock manifold do i need a custom test pipe to make it work?
1990 integra gs
b18a1 5spd
Old May 23, 2009 | 10:55 PM
Jintegragsr97's Avatar
Default Re: type r header on DA
Cut a lil piece off the cross member to make it fit.
Old May 24, 2009 | 07:19 AM
ropeadope14's Avatar
New User
X2
Old May 24, 2009 | 03:23 PM
still4punk's Avatar
My motor is mounted to the crossmember. Would cutting some out weaken it to much to support it?
Old May 24, 2009 | 03:25 PM
MD426's Avatar
I wouldn't go hacking away at everything just to make it fit. If anything you can get it cut out but get a support piece welded in to box in the area that was cut to keep it's strength.
torir278
Apr 14, 2012 06:14 PM
3vilMonkey!
11
Apr 13, 2005 07:08 PM
3vilMonkey!
Jan 15, 2005 08:27 AM
TypeR0936
Aug 28, 2002 10:37 AM
