B20 Swap
Old May 24, 2009 | 10:38 AM
EKris's Avatar
Default B20 Swap
So I got the motor to sit in the bay, but I am having trouble getting the block to mount onto transmission. The clutch/flywheel feels like it's not wanting to go in. Think I just need to play with it and move it around?
It's a b20z2 mounting onto a b16a transmission, non lsd. Any suggestions/help will be appreciated. Thanks!
Old May 24, 2009 | 03:39 PM
ivan93egreppin210's Avatar
Default Re: B20 Swap
the motor is in the bay already? should have put them together out of the car.
Old May 24, 2009 | 03:43 PM
stevenDAtegra's Avatar
It is a lot easier to do with everything outta the car but the thing that is stopping you is probably the splines on the clutch. It will take some manuvering until it sits on right. It may be easier to take the motor back out though
Old May 24, 2009 | 04:24 PM
GStoSubie's Avatar
New User
sounds like a fun time.
Old May 24, 2009 | 05:48 PM
x4thGenCafe's Avatar
OF THE KINGS
keeep on keeepin on. B series is B series
Old May 24, 2009 | 05:57 PM
s2000mansd's Avatar
keep playing with it
and check the clutch disk see if it goes onto the spline
sometimes mistakes happen when u get new clutch and they give u the disk for a cable tranny
Old May 24, 2009 | 06:12 PM
fin781's Avatar
just pull the engine back out. it will in the end save some time.. i did a b20 swap/ls trans in my crx and i pulled the engine out twice before getting it to run due to the transmission. having the engine out will make it easier to bolt the tranny up.
Old May 24, 2009 | 06:22 PM
dc2chickkkk's Avatar
New User
agreed! im a girl and have done three tranny swaps with motors in car and 2 of them were clutch jobs it sucks!!!!!! just pull the motor out its a battle when its in the car unless u have a cherry picker but even then its a Biotch so pull it out and assemble outside of car MUCH easier believe me
Old May 24, 2009 | 10:43 PM
EKris's Avatar
Thanks for the input. I pulled the motor back out, and will pull out the tranny and assemble it then. Will save me a **** load of time and headache.
Old May 24, 2009 | 11:00 PM
nice. It will definitely be a lot easier for you now. Don't forget to make sure your pilot bearing is still in the flywheel after all of the comotion
Wakes4Fun
Jun 4, 2009 02:58 AM
FrOsTwHiTeDC4
Apr 19, 2006 07:36 AM
THMotorsports
Nov 29, 2005 08:45 PM
nominous
Sep 12, 2003 01:00 AM
eg6madness
Aug 1, 2002 10:23 AM
