Just got 5 ABS codes!
Old May 30, 2009 | 10:58 AM
rhino87's Avatar
Default Just got 5 ABS codes!
Hi all,
My ABS/SRS connection was unplugged from the back of my cluster. I had no idea until I took it off today. I retrieved my ABS codes and got this:
11 - wheel sensor (open/short to body ground/short to power) FR
16 - wheel sensor (electrical noise/intermittent interruption) RR
54 - fail-safe relay
61 - ignition voltage
81 - central processing unti (CPU)
(taken from Integra FAQ 98+ ABS Codes)
What should I check for codes 11 & 16? I'm not sure what the descriptions mean. Also, code 61 - "ignition voltage," where would I check the voltage? Please help me if you've done some of this stuff before. Thanks
Old May 30, 2009 | 11:15 AM
1992blueGSR's Avatar
Default Re: Just got 5 ABS codes!
integra abs systems suck, leave it unplugged so you dont have a light and be happy
Old May 30, 2009 | 11:48 AM
racebum's Avatar
possible abs ecu failure. unless some idiot removed parts of it and left others an intact system almost never fails to that extent, code 81 is your real clue to the abs ecu failure.
granted the integra abs system isn't really the greatest. those of you who have driven a porsche or even a corvette know what i mean here. it's like two different worlds of abs. still, having it should make you a little faster around the track since you don't have to worry about tire sliding when you plow the pedal.
lovelove
Suspension & Brakes
Feb 11, 2013 03:04 PM
Whatislove
Honda Civic (2001 - 2005)
16
Jun 14, 2009 01:53 PM
ozzyman
Nov 21, 2003 05:04 PM
Dirt
Jun 6, 2002 05:16 AM
yaksplat
Aug 23, 2001 11:29 AM
